Question about Electric Strider Maxi 4 Wheel Mobility Scooter - Midnight Blue
Overload - Electric Strider Maxi 4 Wheel Mobility Scooter - Midnight Blue
    Novelist:
    Champion:
  • 232 Answers
Check your fuses, replace if they are blown.
Posted on Oct 13, 2010
Where is the reset button on Elna6004 6004, overload message keeps appearing
The message means that the motor is drawing too much current. Could be a mechanical bind or the motor itself is worn out.
Hope that helps.
Aug 19, 2016 | Sewing Machines
Upc 900 why my overload alarme with no charge on it?
The overload circuit normally collects the current information from the inverter leg. At times when there is an actual overload, the protective circuit picked up the excess current as compared to the calculated value and thus gives an alarm. However at times when the inverter leg is short circuit or a leakage it also gives the same overload current. Is the inverter on when it gives the overload alarm? Please let us know.
Mar 13, 2011 | APC Back-UPS XS900 (BX900) UPS System
Overload led constantly blinking
The Overload relay may be faulty. Replace the overload relay. Althernatively turn in the UPS to an expert since there is life power in the circuits.
May 20, 2010 | APC (C73351) UPS System
I'm getting a wierd sound coming from my JBL2088HES refrigerator. It is a buzz like an electric shaver followed by a click. It seems to happen in 3 min intervals. Any Idea what it could be?
Kevin,
It sounds like it could be the compressor overload relay or the compressor itself. Lets hope that it is the overload relay, most compressor replacements are very expensive.
The overload/relay isn't very expensive and replacing it will be cheaper than calling a repair tech to tell you if it is the compressor or the overload/relay.
This is a relatively simple repair, if you look at your compressor you will find two wires connected to a small box ( overload/relay )
To remove the overload first you must remove the metal retainer by unhooking it with a pair of needle nose pliers.
Now remove the overload relay by pulling it away from the compressor.
The relay for your refrigerator has a capacitor connected to it, the capacitor and the relay are sold as one piece part # 67005560.
all that you have to do is remove the old relay with the capacitor from the wires by pulling the plug off and connecting the new overload/relay/capacitor to it, reinstall the relay to the compressor and you are done.
Good Luck
Check us out at www.centuryappliancerepair.com
Dec 10, 2009 | Jenn-Air Refrigerators
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Nov 24, 2009 | Royal Office Equipment & Supplies
I need a contact point at the overloads to interlock a different
If is a " starter" it wil have an overload relay with a NC contact. The newer IEC style starters are actually two components . The contactor and the overload realy assembly. These overload asembliess come in various ranges of current depending on the motor. They usually have both a NO and a NC contact. You didn't furnish the model number of the new starter. You are correct to use a starter to match the overloads to the motor current, not a contactor.
Nov 19, 2009 | Square D Stainless 3p Motor Starter With...
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
Coldtech 65slc-lh-may compressor cycling on overload. does it have internal overload?
Typically, I know all AMERICAN MADE fractional horsepower compressors do not have internal overloads.
I just was not sure if this MADE IN CHINA compressor might have a different internal winding design that included an embedded winding overload. Upon further testing, though, it seems that the start components and overload are external.
Thank you,
Jerry Bullock
Apr 05, 2009 | Coldtech 12 cu. ft. / 340 liter Commercial...
My whirlpool gold microwave model GH4184XSB-1 stopped working after a paper plate caught fire inside. I replaced the wiring going to the thermal overload and the thermal overload but it still doesn't work...
Your thermal overload (thermostat) is bad if the oven powers up when you jump across it.
Are you sure the thermostat is the correct part for your model?
It should be part # 8183703. You can get that here.
Oct 13, 2008 | Whirlpool Microwave Ovens
Electric Strider Maxi 4 Wheel Mobility Scooter - Midnight Blue Logo
67 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
