Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
The female power plug isn't accepting a male plug. Is it a common problem to have malfunctions in the hardware in that area, and if so, can it be fixed?
  • 8,404 Answers
Female rejecting the male ... very common ...
Now for yor problem ... you have the incorrect power adapter ... voltage or amperage is not right for the drive. If this is new ... take it back and get the proper adapter. If it is not new ... check the voltage (ac or dc and amount) and the amps required ... go to Radio Shack or other electronics place and get what you need.
Thanks for using FixYa.com
Posted on Oct 13, 2010
Conector 3 wire male female for generator kubota diesel 11000 i want to bay
You should be able to get this at any hardware store. Take a picture of the receptical so you get the exact plug you need.
Oct 19, 2014 | Electrical Supplies
What should I do to make f-pin coax coupler I bought (to link two coax cables to extend the range of my cable box) receive and display cable programs?
Female to female couplers will only connect to a male plug either side. If the two plugs are female you won't be able to do it, till you either change to two males or get a male to male coupler!
Sep 21, 2013 | Cable Wholesale F-Pin Coax Coupler, 1GHz...
Ac compressor
you must see the plug or connector color + female or male and connect with the respective male or female plug or connector color. You must disconnect the positive terminal of battery for to do this.
God bless you
Oct 16, 2012 | 2000 Hyundai Sonata
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
I have a philips tv model number 55PFL7705D/F7 and serial number YA1A1035007585 and I can't get a sound bar that I bought for it to hook up. It only has 1 audio output I need two. Do you know what kind of...
Most commonly people would use a splitter cable with one male prong and two female prongs at the other end. These are "phono" or "rca" type plugs and the cheapest place to get them is a hardware store. Hope you understand my explanation. Good luck, Russmann.
Apr 29, 2011 | Philips Televison & Video
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
Power cord will not light up where it is inserted into the laptop unless you hold it steady. It will not charge unless it is held in a certain position. Is the male part on the cord bad or is it the female...
You'll need to get another power cord that is identical in power and polarity and plug. One can buy a generic power supply from Walmart that will power most laptops or Radio Shack (Walmart is probably cheaper).
Once the new power supply is obtained, try it, and if the same thing happens, then the problem is in the female plug connection to the motherboard of the Compaq Presario C762NR Notebook.
The Notebook will have to be disassembled and the female plug connection to the motherboard will have to be replaced.
If the male plug end shows any fraying or excessive bending signs, then I would definitely replace the cord.
It is difficult to determine which is bad, the male or female part without changing the easiest part... the power supply.
Also, you could go to your local Compaq dealer and ask to plug in one of their power supplies to your computer and tell them the problem that you are having, determining which is bad, the male or female part of your power supply.
Good luck on this repair.
Aug 17, 2010 | Compaq Presario C762NR Notebook
Power head does not activate
have you pushed the rest switch on the top housing? It may be on the side?
Aug 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Where are the power sources on the GA-K8NF-9 motherboard
You can plug it onto another 3 prong plug on if there is one available on the motherboard. You can also buy little adapters that go from a 3 prong to a molex plug that you can hook to your power supply.
Feb 14, 2009 | Intel Motherboard
Washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
