Thermostat i had before was old so the home owner need a honey well type thermostat
    Guru:
  • 1,524 Answers
Heating only. Cooling only. Combination Heating and Cooling
Posted on Oct 13, 2010
Trying to put new honey well thermostats on but, old cozy thermostat only has two wires. Wires are not labeled, what are the wires?
on a 2 wire t stat the wire color does not matter much .but on the thermostat you want to use rh and w connection point.other terminals are for fan and cooling
Jan 29, 2011 | Cozy (W352E) Heater
I am trying to replace my honeywell T834C2499 with a programmable RTH221. I have hooked the wires as follows: G to G, W to W, Y to Y and R to Rh - leaving the jumper between Rh & rc. My problem is that...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 31, 2010 | Honeywell Programmable Thermostat Heater
I need instructions for wiring a Honeywell thermostat Model# 0924
Go to honeywell.com
Apr 26, 2010 | Honeywell Programmable Thermostat Heater
Two months old hoeywell oil filled hz709 just stopped working ...will not switch on ...please help!
HONEYWELL WEBSITE:
Go to honeywell.com
Mar 13, 2010 | Honeywell HZ-709 Oil Filled Radiator...
I have a boiler system that was turned off at the thermostat for about 5 min. when turned back on it never clicked on again it has a new honey well aquastat relay, new pilot and prob only three months old....
Take off the thermostat and jump the red and white wires together. The boiler should fire up. If not, you will need to check if the boiler has power to the control. It could be a fuse that burnt.
Feb 14, 2010 | Honeywell Programmable Thermostat Heater
I need help programming my home thermostat for heat
HONEYWELL WEBSITE:
Go to honeywell.com
Nov 22, 2009 | Honeywell Programmable Thermostat Heater
With new digital thermostat furnace runs every 10 min.
which type of T-Stat is it ? most standard t-stats have it built in that the temperature range is only a half a degree, it may seem like its running alot more, but in actuality it is maintaining better home comfort as it is not running as long as the old bimetal t-stats which would have a range of anywhere from 2-5 degrees which would cause the furnace to run alot longer, use more energy, use more fuel, and you would notice a definate change in the house temperture before it would come on or shut off, your t-stat seems to be working properly, and it will save you money, remeber also to change those filters !!!
Jan 20, 2009 | Honeywell Programmable Thermostat Heater
How to install thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Jan 17, 2009 | Honeywell (CT62B1015) Baseboard Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Cannot get thermostat to work with previous owners programming.
turn the power off to the thermastat for 5 min (should be a switch on unit) and it should reset
Dec 11, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
