I hace broken wires to my speakers that need to be fixed
    Problem Solver:
  • 9 Answers
Get new wires or new speakers
Posted on Jun 01, 2008
My left speaker has no sound unless i jiggle the cord right at the part where all 3 p;ugs turn into 1 cord. how do i fix it?
The wire inside the speaker cable is broken. You may be able to identify the exact point the wire is broken by bending the wire and unbending the wire. If you can locate the approximate location of the break, you could cut the broken section out then strip the wire, and reconnect. Best to solder if possible. Otherwise, you will probably need to replace the cable or buy a new speaker set.
May 19, 2014 | Logitech X530 5 Speakers
My volume control box is broken, how do i fix it?
Just anyway to gain access to open the box is ok there is no easy way really remove the screws (If) it has any or cut an access hole to reattach the wires just dont damage the speaker is all that needs to be watched for. Remember to rate my solution
Apr 26, 2012 | Logitech X-530 Computer Speakers
How do I take apart the speakers to fix a broken wire? The wire that connects the speakers to the computer is broken very close to the speakers themselves. I need to get the speaker bar apart to...
A unit like this is probably not designed for disassembly or repair. Possibly the grill can be pried off and then access gained from the front by removing a speaker. Or possibly not. If you want to save this unit you may have to get surgical as far as cutting or drilling your way in. Keep in mind that you'll need to mend any openings you make in the case when you are done, to preserve the unit's acoustic properties. Epoxy may be your friend there.
Dec 18, 2017 | Dell AS500 Sound Bar Computer Speakers
Audio amplifier
You Need RCA CABLE, @ or 4 GAGE POWER CABLE (FUSED) From BATTERY SPEAKERS that can Handle the Power , SPEAKER WIRE ALSO to Fit the Duty, .The Hook up all Depends on What you hace for it ....SUB> 1 Channel =MONO 2 Channel = Right & Left or 4 Channel = Frnt Rear Rght LFT . Let me Know EXACTLY WHAT You Intend to do I'll Be Glad to Help !! Need SPECS on All You Got To Set up !!
May 12, 2010 | 2001 Audi A6
My CA-3550 speakers no longer produce sound - but headphones plugged into them work fine... Any ideas? Thanks!
I had the same ones their junk... They don't hace magnetic protection and it says not to put them next to moinitors and other magnetic equpment. The only reason the head phones work is because the cables that send audio signals are still working, It is because the mini sound amps within the speakers have some how distroyed them selves. Its not great and theirs not much you can do acept take it appart and look for either: ( broken/or unsodered wires, or a broken circut). I hope this helps,
TJ
Nov 24, 2009 | Cyber Acoustics CA-3550 Computer Speakers
Need a wiring diagram for radioshack amp 80x80
does it hace rcas ? or high level plug to run it off radio? its red to batt. blue or orange to "turn on amp" from head units 12 v or 500 MA (milliamp) wire black for ground , green /gray or white and purple for speakers and rca pins from radio
Oct 28, 2009 | Car Audio & Video
Broken cord on head phones
You don't need a model number to fix the wire. Any stereo headphone wire will work to replace the old one. Just be sure to check to see which wire is hooked where on your speaker. You need to put the ground wire in the same place the ground wire is on your speaker, the same applying to the hot wire. If you get the two wires backward you reverse the polarity going to the speaker and it will not sound right.
Feb 20, 2009 | Audio Players & Recorders
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
MAx Flash output regardless of setting
Are you still having problem?
atdlee@netzero.com
Jan 29, 2008 | Metz Mecablitz 60CT4 TTL Flash
 Grubhead
Grubhead
