Question about Cutler Hammer Qcd2060 Circuit Breaker
I want to install a cutler hammer 20amp. cuircut breaker in my home. i need instructions on how to wire it up in the breaker box. can anyone help?
  • Anonymous Mar 16, 2014
    I have to run a new wire for an electric oven into the breaker box how do I install a new breaker?
  • 31 Answers
20 amp 120 or 240? All 20 amps 120 must be 12 gauge wire for all connections on that circuit.. no exceptions
120- Bring wire into box securely as is done with all the other wires. Shut the breaker to "off". wire the black wire from the screw on the back of the breaker. white wire to the bar with all the other whites. copper to the same bar or separate grounding bar if available. snap breaker into place. turn breaker on
Posted on Oct 13, 2010
  • 2,100 Answers
Fairly simple job, If you are scared of electricity, hit the main switch at the top of the box. It will shut off everything in the house. Pull the cover off, see those big wires coming in at the top??? (most boxes anyway) they are still hot, don't mess with them. Take off your watch, cuff links, rings. So we can pay for your funeral, only kidding. If you are replacing a breaker, which I hope you are, because if you are not, you need some wires to go with this job. Anyway, peek around the side of the breaker, see those screws? Loosen them up, take out the wire/s, Grab hold of the breaker with your finger tips and yank left if it is on the left or right if it is on the right, It should pop right out. Pop in the new one, put the wires back in, put the panel back on, Hit the main switch. You should be all set. Hope this helps.
I have an old cutler hammer breaker box 30 amp 125/250 250v 3w s/n that hooks up to my dryer. The switch lever thing is stuck in the off position, is this just needing the fuses replaced?
You have provided minimul information but here goes. If the lever is stuck, there must be some reason but I see no way it is electrical. Locking or "sticking" of the lever is strictly mechanical. Now, you mentioned "Fuses" if the box is that old, perhaps you should consider replacing it with a newer version. It is my assumption this box is installed as a service disconnect that is used to turn off the power when service to the equipment is required. Hardly and (if any) full size dryers operate on only 30 Amps. I suggest that if you install a newer box, that you insure your breaker and wiring are of sufficient Amperage to handle modern equipment.
Nov 11, 2015 | Cutler Hammer Electrical Supplies
I need a 200amp main westinghouse breaker typecq200ct 2 pole or breaker box b201632cg
You can check home Depot for the breaker, they're compatible with Cutler hammer.
Mar 11, 2013 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
Breaker malfunction- Breaker won't restore power to the circuit
To do this safely you should call an electrician. No way I can give you complete instructions that will be sure to be safe because I can't see exactly what the situation is that you have. But the basic steps include: turning off the main, understanding that you are about to expose the feed lugs TO the main which are still LIVE (and giving them a wide berth!), carefully removing the cover, CONFIRMING that everything else in the box is NOT LIVE (use a non-contact voltage detector - $15 or less), removing the wire from the old breaker, pulling the old breaker out, plugging the new breaker in, connecting the wire to the new breaker (nice and tight), replacing the cover and then turning the main back on.
Jul 27, 2010 | Cutler Hammer Eaton Electical #BD3030...
What gauge wire do I need to lead into the BR816L125R load center? it is going to the feed through lugs off my 200 amp service breaker.
Hi .. If the load center is next to the main panel you can use #2 copper or #1aught aluminum. You need to use 4 wires .. two hot, neutral, and ground. And in your load center you will need a 125amp main breaker and you will need to keep the neutral bus separate from the box, do not use the bonding screw. You will then need to install a ground bar to the back of the box for the ground wires connection.
any thoughts, questions.?
Jun 19, 2010 | Cutler Hammer Cutler-Hammer...
I have a cutler hammer breaker box & my question is where do the white & ground wires go cuz the bars for them are not the same length one is on the left of the box & the other is on the right
Look at the how the bars are mounted within the box. The neutral wiring (white) goes to the bar that is insulated from the box metal, while the bar that is mounted directly to the box is for circuit ground wiring (bare). Hope this helps!
May 14, 2010 | Garden
CAN A EHD1020 CIRCUIT BREAKER (CUTLER HAMMER) BE USED IN A 120/240 APPLICATION? BREAKER IS IN A SFDN100 ENCLOSURE (CUTLER HAMMER)
For 240 if it is a single pole breaker then no. You need a double pole breaker or 2 single breakers , one above the other, connect the red wire to one and the black wire to the other. this way you are drawing from both legs. hope this helps you...
Sep 15, 2009 | Cutler Hammer Eaton Electical #BD3030...
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Jan 29, 2009 | Cutler Hammer Cutler-Hammer No.BR48L125RP...
Cutler Hammer Qcd2060 Circuit Breaker Logo
359 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Craig Butler
Craig Butler
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
