Question about IBM ThinkPad A30 2652 Notebook
It has a strange sound on boot: 1beep 3 beep 3 beep 1 beep and it doesn't show anything on screen, the harddisk is working....butI can't see anything
  • 1 more comment
  • oktavian77 Oct 13, 2010
    ha ha ha I will find the answer for free my friend...anyway you are very low if you ask for money for that....and only $5...ha ha ha
    I solved it, thanks but I don't need to pay to make it work
    and it was no bios problem
  • 117 Answers
Check if your RAMs are properly seated on their slots and make sure if the connectors are free from dust, rust or corrosion.
Posted on Oct 13, 2010
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 08, 2010 | Acer Computers & Internet
I have an IBM T20 and when I start it up, the screen does not come on, don't hear hard disk working, but the fan is working. There is beeping when started - 3 beeps, then follow by 3 beeps, and then 1...
That is likely. The beeps represent an error code. You might try borrowing an external monitor plugged into your laptop to see if anything shows on that screen when it boots up.
Sep 15, 2010 | IBM ThinkPad T20 Notebook
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
When start on asus motherboard 1beep+1beep sound total 2 beep sou
The problem is the system memory, get yourself a clean, dry soft paintbrush, remove the power cord from the back of the unit, remove the memory and clean the brass contacts on the memory modules, next clean the memory slots of any dust that may have built up and reseat the memory.
Put the side panel back on and plug in the power cord then power up.
Good luck
Jun 19, 2009 | Intel Motherboard
2 beep sound on restart in asus motherboard
memory problem or graphics problem change them
Jan 14, 2009 | Intel Motherboard
Acer Aspire 3 Beeps, No Screen
you will have to find what the beeps mean could be faulty memory or other hard ware problem try removing some memory or using other memory to eliminate memory problems or change video card
Jul 02, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
IBM ThinkPad A30 2652 Notebook Logo
153 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
