Question about Kenmore Refrigerators
1997 side by side model# 1063472090. went on holidays left ice maker on but shut main water in house. now no water to ice maker.
    Guru:
  • 1,524 Answers
Crack fitting by filter to purge. You are air bound.
Posted on Oct 13, 2010
Kenmore refrigerator Monel 1065682 has an ice maker button to turn on and off. Left on vacation and did not shut off. Will the ice maker stop making ice when full or will continue to and overflow?
If water is still on at house it will make ice and stop when full. Don't worry but next time you go Dwayne sure to turn pacemaker off and turn water off to house for safety
Feb 12, 2016 | Kenmore Refrigerators
Ice maker not working after turning water main off in house. Model #GS6SHEXNB02
Sounds like the water filter is pligged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 10, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
My ice maker has stopped making ice. We had to shut down the main water valve to the house and after returning the water to the house is when the ice maker stopped working. We have established that water...
Good day,
For all reasons it is best to do a step by step procedure to get the ice maker up and running.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Apr 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sears model KSRA25FKBL00 How do I remove the icemaker to replace it
Well you can please follow the below steps -
1. Ensure that the water going into the ice maker is shut off. If there is not a valve on the water line going to the refrigerator, check under the house, because there is usually a shutoff valve there.
If there is no shutoff valve for the water line, which is rare, it is possible to cap off the water line with a screw on end cap. If this is the case, you would have to shut the water off completely in the house, cap off the water line, and turn the water back on.
2. Remove the container that holds the ice, as well as any plastic shelves.
3. Remove the screws holding the ice maker in place. There are usually only two and they connect the icemaker to the inside of the freezer.
4. Disconnect the wiring harness that is hooked up to the ice maker.
5. Disconnect the water line from the ice maker.
6. Remove the ice maker.
Please post comments for more help or information........
Good Luck!!
Thanks
Jan 24, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not working went on vacation and turned water off. seems the watr guide into the Ice maker is blocked. Was wondering why this happens, as action should be similar to stopping Ice making with...
When the water is shut off by the lever, it is shut off at bottom of fridge. When you shut it off, it is allthe way to the tray as it gave water permission to travel and what was left filled the line. Unplug fridge for an hour. Should be fine
Aug 09, 2009 | Whirlpool ED5FTGX Side by Side...
I have a GE Profile refrigerator the does not produce ice cubes
the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker wont shut off
So many different types. lots of info needed. In short, lg have DIPswitches on main board. By adjustment of these switches, the water in can be controlled.I dont think there is a water sensor on these makers per say.Does the water ever switch off at any time and if so, is the inflow time constant?. Assuming the solonoid valve is not defective.
Jan 17, 2009 | LG LSC26905TT Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
