Question about Acer ScanPrisa 640P Flatbed Scanner
It does not work. The computer dos not recognise it
  • captabcd Jun 13, 2008
    after uninstalling and then re installing my acer 640p does not work
Hi Sir,
I have Acer Scan Prisa 640C Flatbed Scanner ,which is having parallel port. When I installed the driver ,start to scan ,the computer does not recognise the port ( Parallel Port ).
So please help to solve this problem step by step instruction.
My operating system is Windows XP Professional.
Computer is Intel P 4 --3000
Hdd 80 GB
DDR 512
Thank you.
Posted on Aug 02, 2008
My computer dos not recognise my scanner even after telling me installation was successful
I found out from the scanner makers web site that my computers soft ware was compatable becauce of the age of my scanner thank you for your help.
Mar 31, 2010 | Visioneer 4800 Flatbed Scanner
My computer recognises the hard drive as a folder, and can't access the hard drive to search the contents. any ideas how to fix this?
Check if you hard drive is recognised as dynamic disk (device managment-disk managment), those can be mounted into folders!
TRY to access the drive from DOS PROMPT, to lunch one, go "RUN", and type CMD.
TRY to access your drive frome the adress bar on top of MY COMPUTER window, enter the letter of your drive and hitt enter. (the drive my have missing/extra files manipulating its access, the file can look like "autorun").
If none of the above was helpfull, dont give up, WIN PE minicd can always help, google for it , download it, burn it, and run it, you will certainly find it helfull, and you can access your disk in the browser, and copy the files into the working location!
GD luck
Jan 01, 2010 | VMware Workstation 4.x (WS4-ENG-W-CE) for...
Bios replacing
You will need to download the BIOS installation software for DOS if they have one from the motherboard manufacturer and the BIOS file. You will then need to make a bootable dos cd-r disc using windows. Once you have done this you can use the disc to start your computer in DOS mode. Then burn the BIOS DOS SOFTWARE and the BIOS FILE on a cd-r. Then you will be able to run the BIOS software from dos and install the bios file. You could also install windows on a USB hard drive then try to boot from it if your computer can boot from USB and the USB boot device option is still working.
Nov 26, 2009 | ASUS A8V-E SE Motherboard
Vista Install Issue
This link has at the bottom of the page a bootable cd .iso to download.Burn this iso on cd and boot from it. or download GParted bootable ISO download and burn on cd and boot from there. Its like running FDISK on steroids.
You should configure sata in the bios boot options etc.
Mar 21, 2008 | Intel Motherboard
Umas Astra 5600 connection problem
what computer operating system are you?
Chances are this is a very old DOS scanners for Win 95/8- if your machine is XP/Vista it is not likely to work
Mar 18, 2008 | Office Equipment & Supplies
Blocked Iriver X20
Yes, try running a format from your computer to the IRiver with it plugged into the USB port. I have done this with several friends MP3 players and it works great. In other words plug your MP3 player into your computer as you usually do and from windows or dos in your accessories run a regular format of the MTP portable device or whichever drive dos says it is. Then presto you can again load music or whatever your MP3 player take into it again.
Jan 14, 2008 | iRiver X20 MP3 Player
Toshiba Satellite L45-S7423
Computer questions and answers listing 400 - 499 CH000431, How many partitions can DOS / Windows recognize. ... CH000441, Installing a PC parallel port computer printer.
Determining how much RAM is installed and available. To check how much RAM is available on your computer . ... Notice: MS-DOS 6.2 will not accept or recognize more than 64 megs of RAM.
Good Luck, Please dont for get to Vote, Thank You.
Dec 22, 2007 | Microsoft Windows Vista Ultimate Edition
Gmini 402 camcorder freeze/format
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
May 22, 2007 | Archos Gmini 402 Digital Media Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
Acer ScanPrisa 640P Flatbed Scanner Logo
89 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
