Question about Garden
I have a victor model 100 torch.The spring appears to be broken in the oxygen handle.What is the screw in valve called and where can i get one
  • 760 Answers
Check this manual. It's not for your exact torch, but the parts are about the same. You should be able to go to any welding supply hose and buy parts or have your torch repaired.
http://www.thermadyne.com/IM_Uploads/DocLib_2340_56-1055%20CA%201260%20-%20CA%201350%20-%20CA%202460%20Series%20Cutting%20Attachmen.pdf
Posted on Oct 13, 2010
Moen Posi-Temp Shower Handle removal - Got the screw out but the handle seems totally stuck even after using a rubber mallet - should I use a propane torch and heat it?
You may be able to use a faucet handle puller. The puller is an excellent investment even if you only use it once.
Jan 30, 2017 | Plumbing
I have a Victor R1600 Cutting Torch that the trigger handle malfunctions after a couple weeks of use. The company replaced the first one, but will not replace another, only credit! The problem with the...
Hi:
That's and easy fix and you can do it yourself, call your local welding store like praxair www.praxairdirect.com and give them the brand and model of the torch and they will SHIP direct to you the right part. Check the link here.
Aug 22, 2011 | Victor ST900FC Straight Cutting Torch...
I can't adjust these gauges. How do I do it?
The only part of the gauge that adjust is the tee handle in the middle. the gauge on the left tells you the line pressure to the torch, the gauge on the right tells how much oxygen is in the bottle, usually on a K bottle it is 1800 to 2000 lbs. if you turn the tee handle and the left gauge that tells line pressure does not respond you probably have a bad diaphragm in the gauge. Seek qualified repair man. Thanks
Feb 02, 2010 | Victor CSR350D Oxygen Regulator
Can't remove the handle on Moen shower handle... Seriously!!!
heat it up with a torch, or just break it off, you can call moen at that point and kindly tell them that your handle broke and you need a new handle and cartridge. or you can get a drill and drill the allen screw out, they are such a pain i usually break them when i can get them out and get parts for it then
Aug 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
The handle on my Maytag Quiet series 100
I had the same problem with my QS 100. I disconnected power first via the breaker then removed the 11 screws. I couldn't loosen the two electrical connections, but the door pulled far enough away to inspect the handle mechanism. The plastic handle fell out of whole handle assembly rather easily because two molded plastic pins protuding from either side had broken off and were loose inside. There was also a pair of molded plastic v-shaped forks right on the panel to hold the handle assembly and these were damaged but they just to seem to act as guides only (as the handle assembly is held in by two of the screws that were removed). Replacing the v-shaped forks would require a whole new door which I am NOT doing. It looks like I can a replacement handle in the same color with new pins (I am reading they may now be metal) for about ##15. Pretty easy to disassemble and inspect, only about 15 minutes.
May 29, 2009 | Maytag 24 in. MDB5600A Jetclean II...
We have a victor style medium cutting torch the cutting valve that is sticking open we were wondering if there is a spring in the cutting valve body.
Yes, but usually the valve gets dirty. I've tried to clean them with limited success. I've had torches cleaned at my welding supply house (M-G) for reasonable cost and good results.
Apr 10, 2009 | Victor ST900FC Straight Cutting Torch...
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
