MY TV VIZIO VP50 HDTV20A NEEDS THE FUSE ET8AH250VP,WHERE CAN I BUY IT?
5 Suggested Answers
  • 7 Answers
SOURCE: my vizio vp50 hdtv20a wont turn on i tried
It looks like your power board went bad.
Do you know the part # of the power board, email me at info@hssparts.com and I can get it cheap for you.
Posted on Dec 17, 2009
SOURCE: vizio vw32L-HDTV20A-NO POWER :fuse and q101 q102
You can find these fuses at the Littlefuse web site and look for Part Number: 0215008 it will also give a list of distributers like Newark where you can buy them on line for about $1.00 each.
Posted on Nov 08, 2010
rylee_smith
  • 8619 Answers
SOURCE: my vizio vw32l hdtv20a no
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
  • 1709 Answers
SOURCE: My vizio vp50 hdtv20a has
Hi Check the connections on the back. If all is satisfactory. It may still be under warranty take it to be repaired.
Posted on Jun 07, 2011
Anyone fixed a Vizio VP50 HDTV20A?
Possible T-CON PCB or a burnt out display module.
Oct 31, 2016 | Vizio Televison & Video
Why my tv won't come on? it's plugged inand no light or any thing is happening
Salvador, Could be a internal board issue or power supply, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Official VIZIO Support
Fix Power Problems In 5 Easy Steps What To Do When Your Vizio TV Wont...
https://answers.yahoo.com/question/index?qid=20120504055328AAiBGKi
Oct 28, 2015 | Vizio Sanyo, Ssi320wf12 / Vw32l Hdtv10a...
Vizio model vp50 HDTV20A screen is dim everything works fine however te screen is dim and looks like there is a menu burnt into the background how do I fix this?
Sorry to say, but is sounds as if the TV has been heavily abused.
The menu burn can't be undone. All you can do is age the other parts of the screen to catch up. But that presumes that there's enough life left in the phosphor display to do that. It sounds like there isn't. Sorry, but from what you wrote I think this TV is past salvaging.
Sep 05, 2014 | Televison & Video
Why does my vp50 hdtv20a turns on for about five minutes and then turns itself off
sounds like you have a bad capacitor(s). my TV did the same thing, so I removed the back of the TV and looked at them and noticed (9) of them were bulged at the top ( should look flat). I am no electrician by any means but was able to replace them with a slightly higher voltage myself for around $45 instead of someone servicing it for $400
Jun 25, 2014 | Vizio P50HDTV20A 50 in. Plasma HDTV
Can't remove tv stand from vizio p50 hdtv20A
You have to unscrew the stand from the set, the screws are on the back. I believe there are a total of 8 screws. You will then have to lift the set off of the stand.
Dec 06, 2012 | Televison & Video
Vizio VP50 No sound. I've had the tv for about four years, the sound went out shortly after I purchased it. I have up until now alway's played all sound through surround. Curious if there is an...
It might be,
Audio is usually on a separate power source from the rest of the TV and what I'd do if I were you would be checking the power output on the power board for the amplifier.
It may be something as simple as a blown fuse (and nothing else!) or, more likely, bad capacitor or (again more likely since you said it happened soon after you bought it) blown fuse because of a shorted component somewhere in the amplifier.
Jun 25, 2011 | Vizio VP50 10A 50 in. Plasma TV
My vizio vp50 hdtv20a has sound, but no picture.
Jun 07, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio vw32L-HDTV20A-NO POWER :fuse and q101 q102 bad
Oct 13, 2010 | Vizio L32 32 in. LCD HDTV
My vizio vp50 hdtv20a wont turn on i tried different outlets and still wont turn on its like theirs no power running thru it
Dec 17, 2009 | Televison & Video
Televison & Video Logo
1,262 people viewed this question
Top Televison & Video Experts
Electro Med Services...
