Question about Remote Starter with Keyless Entry
My remote is gone forever. before i get a new or used one i want to know how to program it. i have a 95 chevy tahoe!
  • 344 Answers
All you need to do is remove the 2 fuses for the unit and leave out for 2 min, then replace and press the brakes while holding the brake pedal down press any button on the remote
Posted on Dec 28, 2010
Will a Transmission on a chevy caprice 95 will it fit in chevy Tahoe 95
If the Tahoe is 2 wheel drive the transmissions should interchange.
Jul 19, 2014 | Cars & Trucks
How to program a keyless entry remote for a 2002 Chevy. Tahoe
must take your vehicle and all the remotes to the dealer they will program all of them at same time, if you do 1 you have to do all of them. they can only be programed by dealer scanner.
Oct 29, 2013 | 2008 Chevrolet Malibu
Wiring diagram for 1999 chevy tahoe
I have gone to two mechanices and no one can fix the brake lights on my 1999 chevy tahoe and i dont know what to do i need help because i have been stoped by the police and its not good HELP ME PLEASE!!!!!!!!!!!!!!
Jan 20, 2012 | Cars & Trucks
I need to know how to program a new key fob for my 1999 chevy tahoe and when i program a new one do i have to reprogram the ones already programed to my truck or no ?
The BCM will keep 3 remotes in memory. It takes about 30 minutes to program it without a GM scan tool .The stealer(dealer) will usually do it for an hours labor whatever their rate is. To do it yourself : turn the key on till the security light goes off, press the remote lock button and hold it while turning the key off.Wait a minute then repeat the process 2 more times . The 3rd time the lights should flash and the horn honk and your done.
Jun 28, 2011 | Chevrolet Tahoe Cars & Trucks
My 95 tahoe starts but dont stay on. Fuel wont stay pumping from tbi. Just swapped a motor from 80's camaro. Was running real good in box chevy perfect. Now fuel wont stay flowing out of injectors. Already...
did you install the oil pressure switch origional to the tahoe? The tahoe uses a low oil pressure shutdown, instead of an inertia switch to shut off the fuel pump in the event of an accident. If the pressure circuit does not close within 3 seconds after the engine starts the fuel pump shuts off. This is in case the truck is on its side or upside down the pump will shut off.
Aug 19, 2010 | 1995 Chevrolet Tahoe
Having a problem installing my 791 bypass module on my 05 silverado
I can help you with your problem, you can't find the wires, you don't know what colour they are, it isn't programming, you don't know how to rest it?
Feb 15, 2010 | Bulldog Remote Starter & T-Harness Kit for...
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
Radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
Sep 17, 2009 | 1995 Chevrolet Tahoe
Bulldog Remote Starter On 92 Blazer-Cranks but no fuel pump
I've wired several of these and you have likely hooked up the wires wrong its not giving power to the right wires at the bottom of your steering column...........re check your connections
on your truck there are 3 wires that need power for the starter to work they are the orange,pink and brown
hope this helps!
Dec 30, 2008 | Bulldog Remote Starter & T-Harness Kit for...
PROGRAMING ALARM REMOTE ON 95 TAHOE
Here it is straight from Alldata:
  1. Ground pin G of the Data Link Connector (DLC).**Bottom left pin**
    • Receiver will respond by locking, and unlocking doors within 2 seconds.
  1. Press any button of the first transmitter to be programmed.
  2. The control module will respond by locking/unlocking doors and activating rear window release.
  3. Press any button of the second transmitter to be programmed (if used).
  4. The control module will respond by locking/unlocking doors and activating the rear window release.
    1. Remove the ground applied to the reprogrammed connector.
      1. Transmitter operation is verified locking and unlocking the doors and activating the rear window release
Dec 23, 2008 | 2007 Chevrolet Malibu SS Sedan New Cars
Remote Starter with Keyless Entry Logo
145 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
John
John
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
