Mintek mdp-1050 portable dvd player.problem battery does not charge any more.only plays with AC adaptor.what can i do,thank you.
  • 2 more comments
  • cpeaskitchen Jun 23, 2008
    DVD Player Model 1050 does not play with the battery only when plugged in . What is the problem
  • Anonymous Oct 25, 2008
    I have the same problem. Can't find the battery model online either.
  • Anonymous Feb 26, 2009
    my name is eugene I HAVE THE SAME PROBLEM IF YOU KNOW SOMETHING PLEASE LET ME KNOW
  • dschin Mar 25, 2009
    I have the same problem. I thought the kids had let just let the battery run down, but no matter how long I plug it in, it will not charge the battery at all. Works fine when plugged in to an electrical outlet.
Nickstar19
  • 417 Answers
SOURCE: mintek model: MDP-1050
SOUNDS LIKE YOU NEED ANOTHER POWER PACK FOR YOUR DVD PLAYER
Posted on Jul 02, 2008
SOURCE: MINTEK DVD PLAYER MDP 1815 NOT PLAYING
Mine is doing the same thing. I turn it on, it lights up, it says open, but it won't play dvds or cds. Its not spinning and theres no sound. It used to be a good little player. Is it fixable for a reasonable price or is it shot? Thanks for your help, Jim
Posted on Jul 10, 2008
A3sthetix
  • 41 Answers
SOURCE: Missing AC adapter
If you look at your DVD player, it will have information such as 5V, 2.2A. This information will help you choose the correct AC adaptor. Head over to The Source, FutureShop, BestBuy, etc and bring the DVD player in.
As for a universal AC adaptor. These range from $15 - $50. Just make sure the one you get has the correct plug and voltage/amp range and polarity for it. The salesperson should be able to help.
Here is a picture of such an adaptor. This is a picture of the back of an electronic device, showing 5V and the polarity. If your player has no information with the AC port, you will need to look for a label on the device with this information.
Posted on Dec 01, 2008
  • 814 Answers
SOURCE: I have sound but no picture, can you help
Please give more information, on how you found the problem. Have you tried the video output connected to another monitor to see if the video processor circuits are still functional. You can do this by using cables to the video output of the dvd player to the input of your television. Usually Three wire connections. The yellow connector is for the video and the red and white connectors are for the audio. Make these connections and use your television on a alternative signal source input. This is usually a function button on the television or the remote control. The function is usually labeled input. You can find the correct set-up information with pictures in the owners manuals of the products. If after testing the video ouput from the dvd player. You find that you do have output, then you may have a connection problem between the main board and the LCD screen. These connectors are usually ribbon cables and are a yellow or golden color. They are connected by a clamping connector. The connector is usually released by using a small screw driver to release the clamping device. You can check the connector and see if it looks like it still working. If the connector looks crimped,torn or bent badly it may need replacement. If they look ok , then you may want to use some contact cleaner to clean the connection points and the connector. You can do this by spraying a small amount of contact cleaner on a cotton swab. Take the swab and wipe the connector, cleaning the connection points and then use a small brush with a small amount of contact cleaner to clean the connector. You can also use a can of compressed air to blow all dust and debris from the connector and the circuit board. Make sure to clean all areas of the board as dust and dirt act as a heat blanket and cause overheating problems on the ciricuit board. If all of this seems over your head. Have a friend help you. Or take it to a repair shop for evaluation. There are many helpful videos on you tube that can show you how to do the disassembly and cleaning of the player . Look under cleaning and repairing portable dvd players. If you have a vidoe processor failure, then it may not be repairable. The expense may be more than the cost of just replacing the dvd player. I hope this information helps you with your problem.
Posted on May 29, 2009
  • 814 Answers
SOURCE: no disc error
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Posted on Jun 09, 2009
Portable DVD player Mintek MPD 1770
Hi, yes it should. Have the AC adaptor tested for DC out, you might need to replace it. Most of these prtable units have a rechargeable battery pack, you might want to have it checked out also, because it might be interfering with the AC option as well.
May 28, 2010 | Mintek MDP-1770 Portable DVD Player
My battery does not recharge.
I think that your battery is a dud. If you have been using your portable player on ac all of the time then you have been charging your battery at the same time. You need to play the portable on the battery at least once a month or it will slowly just go bad.
Jan 08, 2009 | Mintek MDP-1030 Portable DVD Player
Missing AC adapter
Dec 01, 2008 | Mintek MDP-5860 Portable DVD Player
Mintek 1760 adaptor
check the input voltage and check to see if radio shack has a universil adapter to fitit! they should have somthing compable...most lickly its 12 volts
Nov 19, 2008 | Mintek MDP-1760 Portable DVD Player
DVD MDP-1810
http://www.amazon.com/Nickel-Metal-Hydride-Portable-Battery-MDP-1810/dp/B000GE47LS/ref=sr_1_7?ie=UTF8&s=electronics&qid=1244518882&sr=1-7 Copy and paste this web page into your browser to find the replacement battery for the Mintek mdp-1810 dvd player. I hope this information helps you with your problem.Comments:Jun 09, 2009- http://www.acdapter.com/mintek_ac_5_adaptera.html copy and paste this web page in to the address bar of your browser to find the a/c and d/c adaptors for you Mintek mdp-1810 dvd player. I hope this information helps you with your problem.
Aug 14, 2008 | Mintek MDP-1810 Portable DVD Player
Mintek Portable DVD Player
The overall life over portable DVD player batteries is terrible.
Here is some information on ordering a battery
Jul 23, 2008 | Mintek MDP-1810 Portable DVD Player
I need a AC adaptor and a AV cord.
Take your unit into Radio Shack. They should be able to match one up for you.
Jul 12, 2008 | Mintek MDP-1030 Portable DVD Player
Televison & Video Logo
472 people viewed this question
Top Televison & Video Experts
