Question about Philips Magnavox 20MS3442 20" TV
My Maganavox #19PSC5 0121 19''
My television is stuck on a demo mode that won't stop. I can't press any buttons on the tv. so I can't turn the channel, turn it up or down, or go to the menu. it's showing reasons why i should buy the television and all the things i can do. I just figured i'll let it play through, but it keep starting all over again. please help me
  • greggregory Jul 21, 2008
    My mom reports the same problem with her older Magnavox... Please help! Thanks very much, and have a pleasant day!
I just found a solution elsewhere on this site...
In order to make the Demo Mode stop, you should press Volume Up and Channel Up together, and hold for four seconds. This worked for my mom's tv, I hope it works for you, mooone (and everyone else, too).
Posted on Jul 22, 2008
My tv model number is 60lb5900-uv how do I get it off of store demo
How To Take Your Tv Out Of "Demo Mode"
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMay 21, 2012 - There are 2 ways to take your tv out of demo mode. ... When the message, "Menu language, store demo, and time will be set", and then press ...
Samsung: LN46B650 is stuck in Store Demo mode - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI just bought a Samsung LN46B650 and it is stuck in Store Demo mode. ... If you do get prompted to choose between HOME or STORE mode (and you might), ... on the tvfor 10-15 sec(i did almost 30)...but the store demo mode wont turn off.
Samsung HDTV - Disable Store Demo Mode (UN46D6003 ...
? 0:39
https://www.youtube.com/watch?v=emPw3NkUuss
Nov 28, 2011 - Uploaded by SPSN
Jan 19, 2016 | Televison & Video
How to emove the demo on screen ?
Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears.
2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method.
Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar.
2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar.
2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Mar 06, 2011 | Samsung LN32A330 32 in. LCD TV
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV is 1995 Model 25TRC1-0101 Magnavox. Seems to
The tv has been accidentally set for "demo mode". Press the volume up and volume down buttons in front of the TV at the same time for about 5 to 10 seconds untill the demo disappears or sometimes the TV will turn off. You should regain control of the TV after this.
Jul 19, 2010 | Philips Televison & Video
Turned off demo mode but it turns back on on its own
Viewing the demonstration (DEMO) mode
The DEMO mode automatically demonstrates several features of
your TV.
To start the DEMO mode:
1. Press MENU.
2. Press left or right button to highlight the SET UP menu.
3. Press up or down button to highlight DEMO.
4. Press left or right button to highlight START.
To stop the DEMO mode:
Press RECALL, EXIT, or POWER.
I hope this helps. Thanks for using fixya.
Jan 20, 2010 | Toshiba 36A43 36" TV
Pre-set message in a continuous loop on tv. Can not get it to stop. Maganavox Model No.: 25TRC10101
Try holding the channel up and volume down buttons together on the front of the set until the set turns off. When you turn it back on it should be normal. If channel up and volume down doesn't work try channel down and volume up. One of the two should do it. This demo mode was for in store demonstration. Thanks
Nov 01, 2009 | Televison & Video
42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
May 19, 2009 | LG 50PC1DR 50 in. Plasma HDTV
LG Model LHT754 stuck in demo mode
press power button on tv,then scroll right to take it back to tv
Jun 30, 2017 | Audio Players & Recorders
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Philips Magnavox 20MS3442 20" TV Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
