Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm WM2455HG - gasket inside door stays dirty
I have a six month old LG Tromm. The gasket inside the loading door stays dirty - it seems to collect whatever solid waste it can. How do I prevent this from happening and what is best way to clean this? Thanks!
SOURCE: Nasty water accumulation from washing machine
I have a LG front loader that also had a smell. We have had it for 3 years and it has had miinor smells before thut this week...it smelled like some died in there. First I ran bleach and hot water through a cycle but still had the smell. Then I put some drain enzymes through a cycle and still had the smell. Then I put Lime-A-Way (or any lime and scale remover that can be used in a washer). I ran it through a cycle and the smell is now gone. I'll see how long it last...but it looks and smells brand new now.
Posted on Jan 20, 2008
MNTECH
  • 1543 Answers
SOURCE: LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Posted on Oct 23, 2008
onthejob5130
  • 640 Answers
SOURCE: LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Posted on Jan 30, 2009
Karthik316
  • 187 Answers
SOURCE: Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
Posted on May 22, 2009
SOURCE: i need a service manual for an lg wm2455hg front
i have thiswm2455hg unit that is to me worthless it doesnt wash the cloths clean i just go through the cycles and the cloths come out spots and not clean it vibrates on spin clycle the cloths look drye when the machine is washing very little suds this is the last front load im getting let me see the agitator in the water not this front load clonker and it stinks after sitting a couple days whats up
Posted on Mar 21, 2011
Reinstall on door Front seal (gasket?) that fell off
Sounds like you need a new gasket - those things just "do not fall off" unless they are worn or no longer fit properly.
Go to attached site Search Over 2 1 Million Appliance Parts
Oct 08, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I need a service manual for an lg wm2455hg front load washer. Where can i get one?
Jun 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Gunky slim in rubber gasket on front door. terrible odor also
that is mold bleach water hand wash rinse with water . afresh cleaner several times then monthly
Feb 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
  • Hi
  • Try these:
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to re-attach a door boot
The door gakset is held on by a round ring on the inside of the drum and another round ring on the outside (where the door meets the gasket). Make sure the gasket is oriented correctly, then starting either on the inside or outside, stretch the ring to fit over the gasket and into the channel. There is a spring on the ring clamp that allows it to be stretched. It is easiest if using 2 needle nose pliers - 1 to hold the ring and 1 to stretch the ring by grabbing the loop where it attaches to the spring. You should be able to stretch it far enough to get the entire ring to fit over the gasket and then onto it before letting it go back into position. Be careful not to tear the gasket. Try to orient the ring so the spring is in the 10 o'clock or 2 o'clock position (to avoid door leaks). Hope this helps.
Jan 12, 2009 | LG WM2688HWM TROMM SteamWasher
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
203 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
