Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
NOZZLE FROM EPSON NX515 IS BLOCKED I DID SEVERAL CLEANING BUT IT DOES NOT WORK
  • 140 Answers
SOURCE: epson c62 print head clogged
The first thing is that you need to get some compressed clean air and blow all that mess up. There is compressed clean air that comes in a can kinda like wd-40 with a small straw. You can buy it at Radio Shack or some electronic supply place. That will do the trick. God Bless.
Posted on Jan 12, 2009
gwbm
  • 353 Answers
SOURCE: I replaced the ink cartridges on my Epson C40UX
I presume your printer was printing all colours before the cartridge change. If you removed the old cartridges a few hours or more before you fitted the new ones, it is very likely you have nozzles clogged with dried ink. If this is the case, do a head soak as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you now get any of the missing colours on the nozzle check, then there is hope! Try 2 or 3 more head cleans (but no more). If still not a full print, repeat the soak process until you get a full nozzle check.
If the new cartridges went in immediately after the old ones came out, it is unlikely to be blocked nozzles. If you changed the cartridges without using the proper procedure with an ink charging cycle, you may well have got air into the nozzles. This just takes patience - try a daily head clean to see if the ink gradually appears.
Finally, you may have faulty or out-of-date (dried-out) cartridges. The easiest way to check this is to try new cartridges in the nozzles that don't print, making sure you use the proper cartridge exchange procedure. Compatible cartridges are very cheap on ebay - £3 a set in the UK.
Please come back with further information on what you have tried if none of this helps.
Posted on Jun 01, 2009
  • 400 Answers
SOURCE: Epson stylus CX4900 cyan not printing but still half full.
The print head on the printer itself is proberbly dry ,you will have to get it replaced by epson.
Or buy another cartridge and see if it does the same ,since it's risky that it too might not work rather get the cheaper compatible ones that way if it still doesnt print then you don't lose too much money.
Posted on Jun 22, 2009
  • 413 Answers
SOURCE: Epson Pro 4000 not used for 3 months & nozzles
More likely the ink cartridges have dried up.
Take them out and see if there is any ink in them...
Posted on Jun 28, 2009
cns assoc
  • 677 Answers
SOURCE: CX5200 STYLUS EPSON...THE YELLOW NOZZLE IS NOT
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Mar 25, 2010
Can you replace the printer head on a Epson R280
You can but you need to have a special tool to do so. The service manual if on-line free it's the first one that comes up if you type "Epson R280 Service Manual" into Google.
If you have a blocked nozzles. The user manual after several cleaning attempts says wait 6 hours then try the clean again.
Jun 12, 2017 | Epson Office Equipment & Supplies
Have nx515 epson printer that will not print in black.Replaced with new still no black. Fix?
Do a head aliment page to test the nozzle operation.
The line on the test page should be in black and white.
Jan 15, 2014 | Epson Stylus NX515 All-In-One InkJet...
Cant figure out to clean nozzle head
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 02, 2013 | Epson Stylus NX515 All-In-One InkJet...
I have an epson stylus 515 i print something and i comes out blank what would you think it could be
Blocked print head nozzles
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Nov 18, 2012 | Epson Stylus NX515 All-In-One InkJet...
Lines in photo
If you have white horizontal lines in your prints then most likely you have some blocked print head nozzles.
Oct 21, 2012 | Epson Stylus Photo R1900 InkJet Printer
My epson black ink wont print??
Oct 10, 2012 | Epson Stylus Sx235w Inkjet Copy Print Scan...
Replaced both color and black cartridges. Prints only color when I try to print a flyer with both text and picture.
The black print head nozzles maybe blocked.
Sep 25, 2012 | Epson Stylus CX3200 All-In-One InkJet...
Will not print black only. Changed ink cartridge 3 times, performed all maintenance repeatedly, but will still not print black ink.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required. Also try - Removing the print head, run it under hot water for 2 mins, then let soak for 10 min. then used a can of compressed air to dry thoroughly. It may fix the blocked nozzles.
Sep 01, 2012 | Epson Stylus CX9400 Photo Printer
Why do i get lines though photo prints on epson sx535w printer
This is usually caused by blocked print nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jul 09, 2012 | Epson Office Equipment & Supplies
I have an epson NX400 inkjet printer, all ink cartridges are full and are installed correctly. When trying to print, the black ink is not being printed. I have tried doing several head cleanings,...
hey friend,
This should be the problem of print head ink nozzle block.The nozzle for the black ink cartridge got dry.So the ink getsdried state.It won't allow any inks passing through the micro nozzles.Head cleaning won't help with the heavy nozzle block.So try replacing a new black cartridge or else bring the printer to the nearest service center.It'll help so.
Mar 06, 2011 | Epson Stylus NX400 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
475 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
