Question about NetGear WGT624 Wireless Router
No connection I cannot connet says no connection when I try to setup a wireless connection the screen doesn't show anything to select. I have have this on the laptop and its been used but it's gone now can't find
  • F-May Jun 16, 2008
    I've been sucessful setting up a connection 3 times, this last time the connection ended after 2 days. My labtop says I am connected Local only? I don't know what else to try?
  • 135 Answers
Check your firmware. Has to be version 3 will not work with 4
Posted on Jun 26, 2008
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
I want to get internet on my dsi
You have to setup your internet connection on your DSI before being able to go on the internet and play online. Here is a step by step instructions how to setup your DSI Internet Connection:Wireless Connection:
  1. Turn on Dsi and click on the wrench button to go to system settings.
  2. Scroll until you see "Internet" and select it.
  3. Select "Connection Settings"
  4. Select "none" next to the Connection 1 button
  5. Select "Search for Access point"
  6. Select your preferred access point
  7. Test Connection
  8. Done!
Jan 08, 2011 | Nintendo Dsi Pink Console
Keep losing connectivity
This is usually caused by the setup of the TCP/IP properties, most people do not have static IP addressing, so open the Wireless Connetion Properties window, find the Internet Protocol (TCP/IP) and select it then select the properties button to bring up another window showing the properties for this, select the "Obtain an IP address automatically" and "Obtain DNS server address automatically", OK out of these dialogs and that should take care of it.
Jun 22, 2010 | D-Link DIR-300 Wireless Router
I am trying to connet wireless printer how can i do this please??
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox). 2. Access the router usually else try 3. Login to the router with the Username as admin and password as password (unless you have changed it). 4. Click on Wireless Settings'(under Setup) from the left menu. 5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'. 6. If WPA-PSK is selected, copy the code entered in the passphrase. 7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless printerto the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Scan for the wireless network on your printer and connect to the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 21, 2010 | NetGear DG834G Router
How do you get the internet
select internet from the Wii settings screen, then go to the internet setup screen.
first, you should make sure you have a high-speed (broadband) Internet connection like cable or dsl. then, you should see if your network is wired or wireless.
-your network is wired, then you have a LAN, and you can connect your Wii with the network with a Wii LAN Adapter which can be sold at
-your network is wireless, then you can use the Internet Setup in the settings to search for your access point. all you have to do is select the connection settings option, select an open connection indicated by "None", select wireless connection, select search for an access point, see if you can select your access point from a list (if it shows up), select OK, and select OK to test the connection
-your network is not wireless, then do you have a PC running Windows XP directly connected to your high-speed Internet connection? if so, then you can connect your Wii if you get the Nintendo Wi-Fi USB Connector and use Internet Setup to connect with it.
we actually have the wireless router to connect to ours and it works perfectly. you can also check the Wii Operations Manual (gray book) for even more details. its on pages 51-59. you should start on page 51 though.
i hope this helped a lot!
Jan 09, 2010 | Nintendo Wii Console
Hi I am using Belkin router & unable to connet through wireless, if I connect directly from wire I am able to connect pls help. My username that is moon sam is not detecting its showing some other name
you are able to go online when the computer is wired that means wired connection is working.
open the router setup page and check the wireless settings of the router
Click here for more info
Dec 05, 2009 | Belkin Computers & Internet
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control connection...right click on wireless properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
Secirity type
try reinstalling the wireless driver
Jan 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
NetGear WGT624 Wireless Router Logo
26 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
