Question about Sta Rite STA-RITE CLAMP ASSY W/ NUT - C119-37S
Clamp nut is stripped. will not tighten and therefore I cannot run the pump. Where do I find another pronto?
    Novelist:
  • 116 Answers
The fastest solution would be just to run to the hardware store and buy a nut that fits the bolt. It is a common size thread. If you want to continue to use the knob you have two options. You can of course buy a new knob. Finding one in stock at a pool supply is kinda hit and miss, you might need to call around, but you should be able to find one if you call or visit a couple stores. A pool pump repair shop should definitely have one in stock; if not new, than at least a used one. Another option is you use a heli-coil insert to repair the knob. I have done this many times and it works great. You can get a heli-coil kit at most auto part stores, and some hardware stores. The kit comes with a tap to re-thread the stripped threads to a larger size, then use the enclosed tool to screw in an insert, and your done. It may be cheaper to buy the knob, but it is an option, and once you have the tool you can use it for other things as the insert alone are fairly cheap, and it is a common size thread your dealing with. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 13, 2010
Testimonial: "Thanks. I had the nut option but with fine thread and a long run-up, it's a pain and temporary fix. Hard to get at as well. Like the rocket!"
  • Derek
    Derek Oct 13, 2010
    Yea I hear ya, when I come across these without nuts instead of knobs, I usually break out the cordless drill and nutdriver with a deep socket. I've also made a custom tool for a customer, by taking a piece of pipe, and epoxying a socket into one end, and drilling the other to put a small rod (like a nail or small bolt, etc) across the opposite end as a handle. kind of trailer, but actually works well. thanks and good luck
Expand-It 40 volt locking collar T bolt stripped
http://www.ebay.co.uk/itm/Un-Used-Stihl-KM-Kombi-Power-Unit-Driveshaft-Clamp-Tommy-Screw-T-Bolt-and-Nut-/322089323385
Give these ones a try.. But NOTE; There is no need to tighten these up that tight.! There is no way that you should have to tighten them up enough to strip the thread.. its holding on an extension shaft together, its not having to hold the weight of a vehicle.
May 24, 2016 | Ryobi Garden
Do u have to replace the hold drain pump bracket if the black hose conected to the pump keeps falling off?
You do not need to replace the whole drain pump. The black drain hose is attached to the drain pump and secured with a hose clamp. If the clamp is not further down the drain hose, inside the unit on the base or has not fallen underneath the washer it can be replaced with a hose clamp from a hardware store. You will need the diameter of the hose to get the correct size. Rather than using a standard screwdriver to tighten the clamp a 1/4" or 5/16" nut driver or socket works much better. Make sure you unplug the appliance before working on it and have towels handy in case of water spills
Sep 02, 2014 | Washing Machines
Harley torque specs
Tighten the top nut of the front cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm), then tighten the bottom nut to 100-120 in-lbs (11.3-13.6 Nm), final tighten the top nut to 100-120 in-lbs (11.3-13.6Nm), then tighten the bottom nut of the rear cylinder head exhaust flange to 9-18 in-lbs (1-2 Nm), tighten the top nut to 100-120 in-lbs (11.3-13.6 Nm), then final tighten the bottom nut to 100-120 in-lbs (11.3-13.6Nm), tighten the transmission exhaust bracket clamp bolt to 60-96 in-lbs (6.8-10.8 Nm), tighten the two bolts with lockwashers, tighten the four TORCA clamps to 45-60 ft-lbs (61- 81 Nm) in the following order, crossover pipe to left side muffler, then rear header pipe to right side muffler, then front header pipe to rear header pipe, then rear header pipe to crossover pipe, tighten the Keps nut securing the bracket tab to the exhaust support bracket, open the worm drive clamps and install the six heat shields onto the exhaust pipes positioning each clamp so that the screw is on the outboard side in the most accessible position and then tighten them to 20-40 in-lbs (2.3-4.5 Nm).
May 04, 2014 | 2005 Harley Davidson FLHTC - FLHTCI...
Pool Filter blowing water through clamp when starting up
One possibility is to use a Sharpie to mark where the tension ring sits, circumference-wise, after tightening it. Next day or two, when the water blows through note where the space between the mark you made and the adjustment screw. If there is a space, the tension ring is obviously stripped. Also, have you considered a crack in the pump housing???
Aug 25, 2012 | Pool & Spa
How do I remove the clamp on a FP5172 so I can replace the pump body. I have a small crack in the front of the pump body. Could I use some type of epoxy to seal the crack?
Thank you for posting your question here on Fixya.com.
Once you remove the nut use a flat tip screwdriver to release the wedged-on band from the plastic housings. They sometimes stick pretty good if they were in service over many years so do not be afraid to work the band pretty hard if it won't budge at first.
When replacing the band use a mallet or similar tool to tap down the band as you retighten the nut. Each time the nut tightens down work the mallet around the band and tighten the nut some more. Continue this process until you can no longer tighten the nut after tapping down the band.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Apr 24, 2011 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Need to change my fuel filter
The fuel filter is part of the fuel pump assembly located in the tank.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve the fuel system pressure.
  3. Disconnect the negative battery cable.
  4. Remove the two fitting nuts while holding the filter.
  5. Remove the filter mounting bolts and the filter from the clamp.
  6. Installation is the reverse of removal. Tighten the fitting nuts to 22-29 ft. lbs. (30-40 Nm).
  7. Connect the negative battery cable.
  8. Start the engine and check for leaks.
To install:
  1. Installation is the reverse of removal. Tighten the fitting nuts to 22-29 ft. lbs. (30-40 Nm).
  2. Connect the negative battery cable.
  3. Start the engine and check for leaks.
Jan 24, 2011 | 2005 Hyundai Santa Fe
How do i change a powersteering pump on a 1995 lincoln continental
  1. Disconnect the negative battery cable.
  2. Disconnect the fluid return hose at the pump and drain the fluid into a container.
  3. Remove the pressure hose from the pump and, if necessary, drain the fluid into a container. Do not remove the fitting from the pump.
  4. Disconnect the belt from the pulley. On 5.0L engines, use pulley removal tool T69L–10300–B or equivalent, to remove the pulley.
  5. Remove the mounting bolts and remove the pump.
To install:
  1. On 5.0L engines, place the pump on the mounting bracket and install the bolts at the front of the pump. Tighten to 30–45 ft. lbs. (40–62 Nm).
  2. On 4.6L engines, place the pump on the mounting bosses of the engine block and install the bolts at the side of the pump. Tighten to 15–22 ft. lbs. (20–30 Nm).
  3. On 5.0L engines, install the pump pulley using pulley replacer tool T65P–3A733–C or equivalent.
  4. Place the belt on the pump pulley and adjust the tension, if necessary.
  5. Install the pressure hose to the pump fitting. Tighten the tube nut with a tube nut wrench rather than with an open-end wrench. Tighten to 20–25 ft. lbs. (27–34 Nm) on 1989–91 vehicles or 35–45 ft. lbs. (47–60 Nm) on 1992–98 vehicles.
NOTE Do not overtighten this fitting. Swivel and/or end play of the fitting is normal and does not indicate a loose fitting. Over-tightening the tube nut can collapse the tube nut wall, resulting in a leak and requiring replacement of the entire pressure hose assembly. Use of an open-end wrench to tighten the nut can deform the tube nut hex, which may result in improper torque and may make further servicing of the system difficult.
  1. Connect the return hose to the pump and tighten the clamp.
  2. Fill the reservoir with the proper type and quantity of fluid.
  3. Bleed the air from the system.
Power steering pump—5.0L
Power steering pump—4.6L engine
Jan 10, 2010 | 1995 Lincoln Continental
I just replaced a front and back brakeline on my 1996 chevy suburban and realized my bleeder screws are frozen, is there another way i can bleed my brakes?
Yes there is another way to do it but go slow and do it wright
Bleed by using the screw nut on the pipes you just fitted by.
Pump pedal 3times fast and hold down get someone to clamp all 2 hoses (1F/1brake pipe over rear axle) with small G clamps and then undo pipe nut on the one without clamp when pedal on floor lock up and do again ,when done 2 times put clamp from other side to the 1 you just done and do the same again to that side, when Front done take clamp from rear pipe and put on front and to the same bleeding to the rear BUT
pump up 3 times and open both nuts togeather and tighten both togeather and do the rear 4 times not 2, ANDTop up M/Cylinder every time , you might find jacking up rear of car is a lot better to remove air
Sep 24, 2009 | 1996 Dodge Grand Caravan
Leg clamp tightening adjustment on a 055 tripod.Under weight the leg telescopes in on itself. Clamp doesnot grip tightly enough on the middle diameter leg tube.
There should be a nut on the other side of the housing of the tightening lever that you can tighten. Turn the lever to unlock the leg then start with 1/8 th turns of the nut to tighten, then turn the lever to lock the leg. Do this until you get the desired locking.
Mar 17, 2009 | Bogen Communication Photography
Fridigaire washer that won't spin
Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Mar 11, 2009 | Frigidaire GLTF1240A Front Load Washer
Sta Rite STA-RITE CLAMP ASSY W/ NUT - C119-37S Logo
142 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
