Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Washer agitator How does one remove the agitator
    Genius:
  • 1,028 Answers
Reove agitiator top underneath is a bolt remove it and PULL UP
Posted on Jun 02, 2008
How to remove the agitator
Washer Agitator Repair Agitator Not Working ... - YouTube
? 7:51
www.youtube.com/watch?v=yxfDICZ0Ses
Apr 21, 2010 - Uploaded by applianceassistant Washer Agitator Repair Agitator Not Working Repair ... of a whirlpool built washer, manufactured under the appliance brandsMaytag, Amana, ... How To Repair Washing Machine Agitator -Remove And Replace Agitator Dogs ..
Sep 14, 2015 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    Kenmore washer agitates on spin cycle
    Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
    Thank you
    Jan 23, 2010 | Washing Machines
    I need to remove agitator from Roper washer Model RAX7245AWO to replace gears on upper agitator.
    There should be a cap on the top of the agitator. Pry off the cap and remove the inner plastic cap down inside the agitator. Remove the bolt in the center of the agitator and lift the agitator out of the washer. Separate the upper and lower half of the agitator and install the new gears. Reinstall everything in reverse.
    Hope this is of some help.
    Dec 31, 2009 | Washing Machines
    How to remove agitator cam from the upper part of the agitator?
    Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
    Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
    Need to remove agitator to remove lodged medallion
    Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
    Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Kenmore-80series washer -the agitator needs to be replaced.
    remove the agitator cap,,remove the plastic seal under just pull straght up with your hand,,inside agitator theres a nut,,remove thi 1/2 inch nut with ractet and pull agitator straight up
    Dec 23, 2008 | Kenmore 24032\24036 Top Load Washer
    Sheet stuck under washer agitator.
    remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
    Dec 20, 2008 | Kenmore 23822 Top Load Washer
    Shoestrings wrapped under agitator
    You will have to remove the agitator. Remove the softener dispenser from the top of the agitator and when you look down the agitator, you will see a 10mm stainless steel bolt. You will need to remove this bolt to remove the agitator. If there is no bolt, try pulling the agitator up and out.
    Nov 03, 2007 | GE WPRB9220D Top Load Washer
    Kenmore 80754 Top Load Stacked Washer / Dryer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
