Question about GE DSXH47EGWW Electric Dryer
I have a Ge DSXH47EG1WW dryer. It will start and run for a minute then it will start beeping, and the led's will light up and it will shut off.
marka19
  • 1430 Answers
SOURCE: I have replaced the ignitor, flame sensor,cycling
The problem is the dryer coils. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video that should help http://appliancehelponline.com/gdryertroublevideo.html
Posted on Jun 14, 2010
  • 240 Answers
SOURCE: ge dryer display flickers and lights flicker
open top and check connections, unplug power and reconnect after done. if this does not solve it then I would replace display board. this dryer is made by LG, controls should be good.
Posted on May 04, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
SOURCE: Bosch dryer is beeping and showing error code, E01
Clean the Duct hose mine was doing the same thing and now it will run the full cycle no problems. Also if you are in a high humidity area it may be blocking up with condensation.
Posted on Dec 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do you replace the bearings on a GE Spacemaker
I looked up your model and it is VERY similar to that of a Frigidaire model. Same rear bearing as a Frigidaire type. The front of the drum rides on felt. The controls are all quick connected with molex blocks so that is not an issue. I ran across a homemade video of the bearing being replaced by a homeowner who is by no means a tech just a guy who can git her done!
I have a manual and the other videos He does 3 and repair photos HERE
Posted on Jan 06, 2011
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Frigidaire LEQ1442ES1 will run only a few minutes. Heats up runs aprox 3-4 minutes then shuts off, starts beeping and lights on the right side of the panel blink rapidly. Pushing cancel stops it and y
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
Oct 10, 2014 | Frigidaire Dryers
How to remove drum from a GE DSXH47eg1ww dryer
disassemble from the front, remove the belt & there you go & if your not sure get a service tech so you dont do more damage
Apr 10, 2014 | GE DSXH47EGWW Electric Dryer
Replacing bearings in a GE DSXH47eg1ww dryer
Apr 10, 2014 | GE Dryers
Stops during cycle
some times the number of flashes and pauses will be an error code counting them could result in a solution also try turning off the breaker count to 5 turn on see if helps
Nov 25, 2013 | GE DSXH47EGWW Electric Dryer
Need to get schematics for spacemaker dryer model # DSXH47EG1WW
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134859700e.pdf here is the dryer tech data sheet. They wouldnt give me access to the service manual.
But, this does have the wiring diagrams, and some general troubleshooting. Hope this helps.
Mike
Jul 29, 2011 | GE Dryers
GE Dryer shuts off w/ blinking and beeping
I just fixed that problem with mine. I tried many, many things. Final solution was vacumming out the holes in the rear of the drier. (Prior to that, I removed the lint filter and holder, checked all connections and vacummed out that area. I unplugged the vent hose to confirm there was no cluggs. I found resetting the breaker would work for about a half hour.) Just vacum out the rear of the dry. Not only will the beeping stop, but as an added bonus, you cloths will dry much faster!!!
Sep 01, 2009 | GE Spacemaker Washer and Dryer Electric...
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
GE DSXH47EGWW Electric Dryer Logo
500 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
