Question about Roper Washing Machines
I have a roper washer. i replaced my old washer, thinking i had a timer problem it was 23 yrs old. my daughter let me use her roper. it does the same thing. it will not drain the water or spin. i have checked the voltage, and even changed the receptacle. my power provider says i dont have a power problem. could it be a weak breaker? thanks, phil
  • 10,865 Answers
Hello Phil. Generally when it won't drain or spin the transmission is bad. This is a very pricey repair. Sorr to have to say this Phil but this isn't worth fixing either. J.
Posted on Oct 13, 2010
Kenmore 70 series Heavy Duty washer model 110.82872100
You should have a couple screws in back or on the sides of the front panel. UNPLUG your washer and take this panel cover off. Check for loose wires and bad connections at the terminals. If you find a frayed/cut wire you can use electrical tape to fix the issue. It might be something as simple as a loose connector, but if it looks like a broken connector try to take that part to a repairman in your area for servicing.
I would advise that you leave this washer UNPLUGGED completely until you get it fixed/replaced, though. This is the type of thing that starts undetectable house fires in the middle of the night...
Jan 31, 2009 | Kenmore 22422 Top Load Washer
Its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Jan 15, 2009 | Roper RAX4233PQ Top Load Washer
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
ROPER RS22AQXMQ SIDE BY SIDE REFRIGERATOR PROBLEM
I had the same problem with a top freezer. I found that the thermostat was bad by tapping on the it at the setting knob. The defrost timer was replaced first which did not help (repairman put in a timer for a Frigadair which will not work in a Roper). If one is used for a frigadair as soon as it cycles it will not work again until it is unplugged and allowed to reset. I replaced both the thermostat and the right defrost timer. It has worked great for over 2 months.
Hope this helps.
Sep 10, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Frig shut off
my 7yr old roper refrigerator top freezer stopped cooling and freezing but the light was still on with no fans. I dropped the thermostat cover and jumped the thermostat wires,no help . then i removed the wiring harness from the defrost timer and jumped the #1and #4 .She kicked off. I then replaced the defrost timer and it is running fine now
Jul 16, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Roper won't spin
you need to replace the clutch assembly. requires special tub wrench. and some experience
Jan 13, 2008 | Roper RAS6233KQ Top Load Washer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Washing Machines Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
