Question about Protron PLTV-32 Television
Proton pltv- 3250 32 "lcd tv a friend gave me
Proton pltv- 3250 32 "lcd tv a friend gave me this tv . it doesnt have a button to turn it on. What am I missing?
    President:
  • 2,777 Answers
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Posted on Oct 13, 2010
Sound works < but no picture
Proton LCD TV, Hi, most LCD's and Plasma's have a cold/ hot circuit and the board for video and audio are the same usually it's a main board but before going through all that check to be sure that it's not a setting or volume adjustment. older model proton TV's exchange the main board these usually go bad IU would search any auction sites for a similar model with a broken screen and take out the needed parts for this fix, otherwise your better of getting a more updated LCD TV good thing is that they are way cheaper now
Feb 26, 2014 | Protron PLTV-32 Television
How can I adjust the picture colors?
There are several performance issues you may encounter with your Protron PLTV-37C LCD television.
Some problems include the television not turning on, issues with the TV's picture and issues with the TV's sound.
Depending on the type of problem you encounter, there are several options available to you to solve it.
Power Issues
Check the TV's main power cord. If it is not plugged in or is loose, securely plug it in to an electrical socket.
Unplug the television and plug it in to another electrical socket.
If the one it is plugged in to currently is bad, the television does not receive power.
Try turning the television on with the remote.
If that does not work, try turning the television on with the power button on the TV's front panel.
If that works, then remove the battery cover from the remote.
Remove the current batteries and replace them with fresh batteries.
Picture Issues
Check the video cables.
If they are loose or disconnected, securely connect them.
Adjust the television's brightness.
If the brightness is set too dark, images on the screen are extremely difficult to see.
Check the power indicator on the front panel of the television.
If it is red, the television is in power-saving mode.
Simply press any button on the remote to bring the television out of power-saving mode.
Audio Issues
Check the audio cables. If they are loose or disconnected, securely reconnect them.
Turn to different channels and adjust the volume.
It is possible that some channels are coming in quieter than others.
Access the audio options from the main menu. Check what audio setting the TV is at.
If it is set to "Mono," change it to "Stereo."
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=dde1880d298054849d8c8adc90514f40&modelid=22971545&q=Proton+CS-37
Specifications for Proton CS-37 / PS-47
Aug 09, 2013 | Protron PLTV-37 37 in. LCD Television
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Proton 34 LCD tv
Looks like Power Supply fuse is gone. Replace with recommended rating and type of fuse and try again.
May 18, 2008 | Protron PLTV-37 37 in. LCD Television
Protron pltv 32 directv remote code
Protron 32", new Directv R66 receiver/remote. Code is 10030. Works
Feb 02, 2008 | Protron PLTV-32 Television
Lost power cord
Proton Introduces Elegant 37-Inch Puriti™ High-Definition LCD TV ... Each Protontelevision combines forward-thinking industrial design with the most ...
www.proton-usa.com
Nov 17, 2007 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-32CM LCD no picture
This TV set is still under the warranty and it seems proton has no local service available to you. I know its to late to tell you this but anytime you purchase a set, ask first and see if there is a service local to you. Ok enough of that noise.. I would go back to the store where it was purchaced and ask them if they know of any local shops that handle the warranty repairs.. If you want to pay for the repair, and that will most likly be alot for a flat panel set, You will have to call back proton and ask about the shipping cost and whos responsible for that.
Sep 30, 2006 | Protron PLTV-32 Television
PLTV-32
Have you asked proton about the bulb or inverter or power supply. Proton is going to be the only place to get them. Soory to have to tell you but proton doesnt have good customer service.
Aug 11, 2006 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
152 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
