Question about Weather King 12AJA3601AH Air Conditioner
We have a model 12AJA3601 in our daughters mobile home. It has stopped blowing cold air. The fan is working and air is blowing, but is not cold. It was fine a few days ago. I cleaned off the grills, but not sure what else I can do before calling for help. It isn't making any unusual noise. I don't have the manual so not sure if there is a troubleshooting section.
    Scholar:
  • 80 Answers
Possible low refrigerant charge.
Maybe also a compressor not performing correctly.
May sure all wires are secure in the t-stat especialy the yellow wire it calls for cooling at the compressor unit!
Posted on Oct 13, 2010
The home thermostat is on "heat" but is blowing cool air. It does not stop when "off" is pressed.
https://answers.yahoo.com/question/index?qid=20060610162817AAgWgcH
Nov 12, 2014 | Dryers
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
In my mobile home I have a coleman furnace model number 7970-856. It was over 100 degrees today and my furnace fan is stuck running and I don't now if it's supposed to do day. There is no fan switch on the...
There is a fan cycle switch that turns on the fan when the unit heats up (so it won't be blowing cold air) and runs the fan after the unit has shut off to remove heat from the unit. Sounds like it bit the dust. It is located next to the firebox.
Jul 29, 2009 | Heating & Cooling
Vw polo heater blowing only cold air
Daughter's R reg VW Polo has heater probs, only just started, fan working fine and temp gauge works normally but only blows cold air. What do you think could be the prob ?
Mar 25, 2009 | Volkswagen Fox Cars & Trucks
Heater blows cold air
maybe the heater matrix could be at fault, thats the bit that controls the temperature in the car.
Jan 24, 2009 | 2001 Ford Windstar
Weather King 12AJA3601AH Air Conditioner Logo
130 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
