Question about Kenwood KM400 / KM410 Chef Classic Stand Mixer
Goodmorning - I need a new rubber seal to go on the bottom of my liquidizer. Are they available and if so where would I purchase one. Thank you
The drip ring and a seal ring dropped into the batter how are they attached on a Kitchen aid MOdel k5-a
The drip ring is held in place by friction. Simply put in place and tap it around with a small hammer (use a piece of wood between the ring)- and hammer).
I don't know what you mean by a "seal ring." The only piece I can thong of is a rubber o-ring around the agitator shaft (where you attach the beater). If it somehow broke and worked loose you will have to disassemble the machine to either replace the shaft assembly or to fit a new o-ring. The K5=-A service manual is available on line with a bit of searching.
Oct 09, 2014 | Food Mixers
This is missing the manual and the hook for kneeding bread. I would like to download a manual. Is there a part number for the kneeding hook?
Need your exact model number from the bottom and back of your stand mixer. You can enter the model number on this webpage to find out if the manufacturer has made a manual available on-line.
If there is no result contact customer support at 1-866-698-2538.
If this was a new purchase that should have contained the manual and hook I would encourage you to contact customer service or return to the vendor for replacement.
For available mixer attachments click on Stand Mixer Attachments & Categories here. (bottom left)
Jan 29, 2011 | KitchenAid KSM 500 325 Watts Stand Mixer
Oil is leaking
The sealed bearing are probably leaking. They will need to be changed. Or, clean the unit well before using and wait for the bearing to start to freeze up, then get it fixed. Might work for a long time with weaping bearings.
Apr 30, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Nov 29, 2008 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Oil seal
1. Remove the acorn nut, hex nut, and washer that hold the "planetary" agitator section on the transmission shaft.
2. Remove the trim ring (if any) around the same.
3. The agitator section should now be able to be worked free.
4. Remove the retainer clip on the top of the agitator shaft. (Some models have a pair of hex nuts here; if so, remove those.)
5. Pry the gear up and off the shaft. Remove the square key from the shaft keyway at the same time.
6. Tap gently on the top of the agitator shaft to drive it out from the bearings and grease seal.
7. Recommend removing and replacing the top bearing at this time; it's inexpensive to replace, if you're in this deep.
8. Use a suitable diameter piece of round steel stock to drive out the lower bearing and oil seal. I don't recommend using the agitator shaft.
9. Clean thoroughly, insert a new bottom bearing and oil seal, drive in place with a rubber mallet.
10. Replace agitator shaft through oil seal and bearing, tap gently into place.
11. Fill cavity with approved lubricant. I use USP-grade mineral oil, as it is food-safe and provides satisfactory lubricity.
11. Install top bearing, tap gently into place.
12. Reverse steps 5-1 to reassemble.
Aug 24, 2008 | Food Mixers
Kenwood Chef (model no.KM 300)
Hi, check in ebay.co.uk if the seller have worldwide delivery.
or check in kenwoodworld.com
remember for model km only fit A993 and A337
best Regards
Kenwood Chef Restore
May 28, 2008 | Kenwood KM300 Chef Stand Mixer
Kenwood KM400 / KM410 Chef Classic Stand Mixer Logo
116 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Owen Barnes
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
