Question about VAX Appliances Vacuums
Vax carpet shampooer wont release shampoo
Hi, My Vax Rapide carpet shampooer wont release the shampoo/fluid when i use the trigger on the handle. I've made sure its all clean, but the belt has just gone as well......is the shampoo not releasing a seperate problem to the belt going? The problem did seem to start before the belt went.Have you any suggestions to try fix the release of the shampoo or is this terminal?
  • guvenchy Dec 28, 2008
    I have the same problem, cant seem to locate the Jet as mentioned please can you give further help, model is a V-025 Vax Rapisde.
    Thanks
If you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
  • 868 Answers
Its probably a broken jet.Every model has different types of jets so you need to locate it first make sure its not clogged.its easy to find,usually sits near the rotating brush.
Posted on Jun 02, 2008
I have just bought a vax vcwrs700 carpet shampooer at a garage sale. With it came a bottle of bissell x2 carpet shampoo. Woul you know how much shampoo I should know please?
probably a cap full from the bottle
make sure that you use the suds restrictor liquid as well or the suds will come up in the bucket and block of the vacuum flow
Oct 24, 2016 | Bissell Vacuums
My vax model vrs7w wont release cleaning fluid
Sticking valve or blockage. Refer to handbook.
Aug 17, 2014 | Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
Instruction manual for vax integra
We took the entire back off (there are loads of deep-seated screws so this takes a long screwdriver and patience!.) You will see that the valve to release the solution is operated by a cable which runs from the trigger down to a plastic cam, which then operates another cable to release the liquid. We found depressing the trigger was hardly moving the cable at all, so the valve was barely opening.. We took the cam off (it's a boomerang-shaped piece of plastic held on with one screw) and put two small squares of gaffa tape on top of each other onto the top surface of the cam, to imprive the efficiency of the trigger motion. It seems to have worked.
Feb 23, 2012 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax rapide not realising water out
I have just managed to fix the problem i had with my vax rapide not releasing water. I also tried tilting it and that did not work. I unscrewed the brush from the base of the carpet washer and there is a black plastic strip with holes in where the water comes out of and onto the carpet. I used a needle to unblock these tiny holes which had become blocked after the last use. I now have it working again.
Nov 12, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Vax problem
Could be a bad pump.
Feb 07, 2008 | Vacuums
Vacuums Logo
1,706 people viewed this question
Top VAX Appliances Vacuums Experts
richie46
Jim
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
