Question about Cameras
How to load 35mm film/canon t70 - Cameras
5 Suggested Answers
  • 44 Answers
SOURCE: what lens do I use
Any Canon EF series lens except EF-S lenses will work with your Canon EOS Film Camera (EF-S lenses only fit Canon digital SLRs).
Posted on Nov 22, 2008
Obertelli
  • 3006 Answers
SOURCE: Canon EOS 500n 35mm Film Camera, best cheap lens
In short, you won't. All Canon Digital SLR's use the same lens mounting system as your EOS 500n and new lenses are very expensive especially for those who have purchased full-frame models.
As a result, demand for the lenses which fit your camera is very high and so prices are high as well: it's just basic supply and demand economics. There were cheaply made kit lenses available with your camera when it was new, but like most kit lenses they weren't built to last, so most of the older ones are either non-functional or have been scrapped after owners upgraded. All that leaves are the higher quality, well built, lenses from the time your camera was made which are far cheaper than new lenses but still comparatively expensive.
If you want cheap lenses then you've picked the wrong system. Buy an older FD mount Canon SLR if you want to stay with Canon; you'll then find that lenses are so cheap that they're often offered for free on your local FreeCycle group. The same source is where I've got all of my manual focus (and some AF) SLR equipment over the last few years.
Posted on Mar 14, 2010
Testimonial: "thanks for that! i get it now, though i found a lens-http://tinyurl.com/ykjgckr would that work or should i just buy a new one? thanks heaps! :D"
  • 225 Answers
SOURCE: I HAVE A CANON EOS REBEL T2 35MM FILM CAMERA AND
Yes, you should be able to use them. Be aware, moving to digital there is a 1.6 crop factor. The means your 100 mm lens will have the field of view (FOV) of a 160 mm. No, it does not mean it is a 160 mm it is the fFOV is the same as a 160 mm. Also, at the other end is were you will most want to purchase a wide angle lens.
Example: your 28 mm film lens now has the FOV of 44.8, not wide angle. As you can see wide angle is where the move to digital crop sensor cameras lose out. To get back to wide angel you would need a 17 mm lens, that would give you 27.2 mm FOV.
To figure FOV take the lens multiply it by the crop factor. On a Canon it is 1.6, on a Nikon it is 1.5, the 4/3 sensor is 2.0.
Posted on Nov 01, 2010
  • 102366 Answers
SOURCE: I need a manual for
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/d_eos/EOSREBELT2_manual.pdf
Posted on Feb 01, 2011
All pictures have blue tint with T70 35mm SLR
Silly question, is there a filter over the lens? Some folks when using use daylight film in tungsten lighting will use a blue filter. Is the film expired past a few years? If those are all no, then it may be your lab, my suggestion is to contact them. With film there is little to go wrong, you shoot they develop. The magic occurs during developing and printing.
Nov 06, 2013 | Canon T70 35mm SLR Camera
Lithium Battery
you can download a manual here.
http://www.photo-manuals.com/manual/canon/film-slr-camera/t70/
page 74 shows the battery compartment.
Mar 12, 2012 | Canon T70 35mm SLR Camera
The film won't re-wind in my Canon T70. Can I do this manually?
No. If it will not auto rewind you must in a change bag or completely dark closet open the camera remove the cartridge then manually rewind the film. All that in complete darkness. Then get the camera fixed.
Oct 11, 2010 | Canon T70 35mm SLR Camera
Have a canon T70 camera I picked up off ebay. Loaded it with film and took a pic of my daughter. Aftrer i shoot the pic the camera did not rewind to the next frame i noticed the shutter locked up about...
Completely. The shutter is badly damaged and I'll be very surprised if your fix has permanently cured it, but fingers crossed... If not, there's only one fix. Chuck the camera away (spare shutter assemblies are nearly as rare as hens' teeth/fresh **** ****) and replace it. There are loads of T-series bodies and later Canon EOS triple digit/Rebel models available for free just by asking on FreeCycle and Freegle. Note that the lens mount used on the T-series is different to the Canon Autofocus mount used on later models. Also plenty of all the other makes as well. You may have to wait and to ask a few times, but it's where I still get the majority of my 35mm film camera equipment.
May 21, 2010 | Canon T70 35mm SLR Camera
I NEED A CANON COMMAND BACK 70. WHERE CAN I BUY SUCH A CAMERA COVER FOR MY SLR CANON T70 35MM SLR CAMERA
Canon has not sold those for quite a while. Your best bet is to go to Ebay, Film cameras, film camera body acessories, type in Canon Command back 70 and wait until one shows up.
If you save the search, you get an email everytime one comes up. Good luck.
Dec 28, 2009 | Canon T70 35mm SLR Camera
Film won't load.
check batteries, if they are old substitute with known good batteries. One of batteries may be problem test individually under load test! . good luck
Aug 27, 2009 | Canon T70 35mm SLR Camera
Is our Canon T70 dead?
It sounds like the motor is locked up. The gears under the bottom of the camera may have gotten sluggish from dried out lubrication. You can take the bottom off to see if the gears are able to turn freely or check with a local camera repair shop.
CameraRepairs
Apr 16, 2008 | Canon T70 35mm SLR Camera
Film won't load...
Check for batteries, film pressure plate on the back door of the camera, film leader and perforations ,freeness of the spool of the film cartridge,.
Apr 02, 2008 | Canon T70 35mm SLR Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
