Question about Whirlpool Duet GHW9150P Front Load Washer
My reply I did not think you were trying to second guess the issue. I wanted another opinion. Do you know if this sounds right and is it a very common problem? Thanks
  • Marilynik Jun 02, 2008
    Thanks for your comments and help.
  • 5,911 Answers
I understand. This can be a common problem, especially if you have hard water or well water. Basically any water source that calcifies or has sediment. If this is the case, many home owners will install a whole house water filter on the washer line to prevent this from reoccurring. If this is not the case with your water, I would assume this was just one of those failures that could be attributed to normal wear and tear. Good luck to you and keep me in mind if you need further assistance.
Posted on Jun 01, 2008
My SANSUI tv model SV2918 pictures are waving right to left or left to right. Kindly let me know the fault I will fix it. I love Sansui. S. Muyambango, Zambia
Glad someone loves SANSUI...cause I don't, In my opinion they're a poorly engineered TV with lots of issues. What your describing sounds like a pincushion issue, if you have the service manual check various voltages in that circuit, without seeing a picture of what its doing that is only a guess however..
Feb 23, 2018 | Sansui Televison & Video
How do I get my Dyson to stay in upright position. It will not lock into place.
Which model of Dyson do you have. I am going to guess it may be a DC25. It is a common problem with that model. Let me know and we will see if we can help you.
Jul 19, 2014 | Dyson DC25 All Floors Bagless Upright...
LG Flatron W2253v backlight blinking.
The powering off and on the back light is due to bad capacitors. Go ahead and explore the internal power supply. This is a very common issue on LCD I have fixed about 8 of these ranging from 1 yr of use to 9 yrs of use. I own 4 LCDs and have fixed 3 of them. 2-X2Gen, 1 Samsung and one Viewsonic. The latter one is running with out an issue and the one I use the most.
Once you open your lcd look for plunged capacitors. Replace as necessary. The fix should cost you less than 20 bucks
Check this pics for power supply removal, bad caps and new caps.
Well, pictures are over 4mb let me know if you are interested in seeing more pictures relating to this fix.
Mar 25, 2014 | LG Computers & Internet
Timing cover leaking
It is a big job to replace the timing cover gasket everything between the engine and front bumper needs to be removed then the engine removed to do the job properly if everything goes well it's a 4 HR job if not 8hrs sounds about right
you could try an independent specialist mechanic for a second opinion
This is 2017 so if your Subaru is a 2010 it is 7 years old not 3
Nov 13, 2017 | Subaru Cars & Trucks
I have a 98 kawasaki prairie 400. starts right up and runs great but it will only get up to about 30 mph and then it just wants to sputter and backfire if you try to push it any faster than that. at that...
Hey Frank,
This could be the issue, has this atv been sitting up for a length of time? ... I would put a new spark plug in first,, you may have water in the carb.....you can drain the float bowl and put in the new plug,,, see if that cures it, other wise get the carb professionally cleaned and set. Try this and reply to me.
Jun 16, 2017 | kawasaki 2005 Prairie 360
I've been told that my greabox "is bad and your gears could jam at any time" by a garage today. I'd taken the car in due to a whirring "loose" sound when I change gear but the noise is...
If you have a smoky problem don't bother
with the second trans & clutch opinion
GET RIDE OF IT
Clutch Service $900.00
Trans Issues $2,200.00
Engine Work $2,500.00
Still want to keep it ??
Apr 01, 2011 | Ford Escort Cars & Trucks
I have a 2003 road king. I have a transmissiion growling noise when the bike is in neutral that winds down and stops when i pull in the clutch lever. Any advice on where to start?
Since the noise "winds down and stops" when you pull you pull in the clutch lever, this tells me that the problem is indeed inside the transmission. To try to guess exactly what the problem is is very difficult or impossible. I've torn down transmissions that were making a noise and repaired them without ever determining exactly what was causing the problem. If I had to take a guess, I'd probably put my money on the trapdoor bearings on the right side of the tranny. But, if I were going to repair the tranny, I'd replace every bearing in the unit and I'd inspect every other piece in it. Rebuilding a transmission is to large of a job to take shortcuts. You need to take the bike to a someone with known ability and get their opinion of what the problem is. A transmission rebuild is an expensive job unless you have the proper tools and experience to do it yourself. Still it ain't cheap.
Now, this may not be what you want to hear but in my opinion, it's the way I'd go. Just like going to a doctor, always get a second opinion when you think it's something big. Especially since I cannot hear the noise. I'm basically guessing here. Good Luck.
Feb 15, 2010 | 2006 Harley Davidson FLHR Road king
I took my 96 geo prizm to a garage it sounded like it was running on 3 silinders they told me it only needed a tune up i changed plugs wires cap roder fuel filter still does not run right i brought it back...
what do you want to know? So they didnt check it very good, or just guessed the problem. After 2 days, they should KNOW what it is, not THINK. take it to a real garage..
Oct 17, 2009 | 1996 Geo Prizm
Problem with starting
what second opinion... you have confirmed basically that it is indeed the starter. remove it and replace it you should be fine.
Robert
Sep 16, 2008 | 2001 Toyota Camry
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
