Question about GE 60minute Automatic ShutOff Timer Switch 15069
I am replacing an in-wall timer switch that controls porch lights. Old timer has only two black wires, that were hooked to the 2 black wires in the wall. The new timer (GE 15086) has black, red, white and green wires. Wall has only 2 black wires plus green. House built 1996. By hooking switch black to house black and switch white to house black the switch works for setting timer, time displayed, no fire and sparks, but when I turn on lights it only holds for a second, then turns off. By switching and using switch red to house black I get the same result. Would appreciate any help
  • 1,606 Answers
The original timer either was a mechanical wind-up clock or it used a "power stealing" circuit to keep itself powered while it was turned on. The new timer doesn't have this feature. While the light bulb is off, it can run on a small amount of power drawn through the light bulb, but when it turns on the bulb, there is not enough voltage left to keep the switch electronics powered, so when its power supply capacitor runs out of charge, it can't keep the bulb turned on. It probably also forgets its settings.
The only (safe) way to use this model is to bring in a neutral wire. The timer should be connected as follows:
Black: connect to house black from panel (always live when breaker is on).
Red: connect to house black from light fixture.
White: connect to house neutral (white).
Green: connect to house ground (bare copper or green).
If the wires in the box come from one of the porch lights through a conduit (this seems likely; I don't think there are any other legal methods that would leave out the white wire), then it should not be too difficult to add the white wire. Tape a pull string to one end of the wires and pull them out of the conduit at the other end. Bundle a 14 gauge white wire with old wires (tape it to the pull string) and mark the black wire that goes to the light bulbs at each end so you know which one to connect to the red timer wire. Put some wire pulling lubricant on the wire bundle (it will probably pull a lot harder with the extra wire) and pull it all back into the conduit using the pull string.
Note 1: It's tempting to just push the white wire in with the others remaining in place, but it will probably jam when it runs into a place where the others twist around each other, most likely at an elbow in the conduit. That might damage the insulation of the other wires.
Note 2: 14 gauge is the typical size for a residential light circuit. Use the same size that's in there now, and be sure it is a type UL listed for residential power wiring. Look for the fine print on the original wire; you should be OK if you match that. If more than half of the conduit cross-section will be filled with wire when you add the neutral, consult a licensed electrician to be sure you won't have a problem with crowded wires overheating.
Note 3: An alternative is to use the original wires to pull in a 14-3 cable (black, red, white and ground), provided the conduit elbows have a large enough radius to let it go through. However, the jacket on this cable has considerably more friction than the insulation on wires typically run through conduits.
What happened to the original timer? Maybe we can figure out how to fix it more easily than rewiring the box. I know there is at least one two-wire electronic timer on the market, but I'll have to go over to my church and look up the brand and model. Check back after 7:30 pm CST Oct. 13, 2010.
Posted on Oct 13, 2010
Testimonial: "The white was tucked in the back of the box and painted over so I didn't see it. By connecting as you suggested it woks just super. Thanks"
  • 2,100 Answers
Did you get instructions with the switch? Does it say what is line and what is load? You can hook the green and the white to the green, it won't hurt, but I think one of the colored wires is in and one is out, you have to find out which one is hot. Got a tester? The new timer is polarized for modern electricity, which hasn't gone into effect yet, it is coming. Your house wouldn't have it. If it does, you will know by the fuse box being separated by ground and neutral, the old ones were wired together. If it is, the new switch will only work with the white wire to neutral and the green to ground. Now that you are totally confused. try wiring it up with the green to ground, red and black to to the 2 blacks. See what happens. Hope this helps.
Testimonial: "Gread advice, it worked likje a charm. Thanks very much"
Porch light timer switch problem
0192773 is single-pole only.
I think you have wires reversed or attached incorrectly:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 31, 2014 | Hardware & Accessories
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
We have a motion sensored light with two lights and the motion box. 1 black wire and one white per light but the middle has 1 black, 1 white and 1 red. We are hooking it to the porch light and dont know...
You are replacing porch light with light fixture with motion sensor device.
Each light has 1 black and 1 white wire.
The motion sensor has 1 black 1 red 1 white:
Copy following link for motions sensor wiring illustration:
http://waterheatertimer.org/How-to-wire-switches.html#motion
Oct 17, 2012 | Hardware & Accessories
I bought a Utilitech Self Adjusting In-Wall Timer #0192773. The Timer has 4 wires....a black wire...a red wire...a green wire...and a white wire. The switch that I am replacing has 2 black wires and a bare...
The reason there is 2 black in the wall is because a standard line breaking switch was used. Meaning the hot side of the light was the black wire once broken light goes off. You would hook the black from switch to black in wall and white from switch to other black in wall green is ground and red put wire nut on. Red is for a 2 switch system. Where one of two switches in same room controls same light. Its not needed. Take caution when doing this trun light on goto breaker box and flip breakers till you find the right one that powers that light. once lights off then do your thing replacing.
May 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Purchased utilitech 0192773 self adjusting wall timer. planning on installing in garage wall switch box for outside lamp posts, 3 total. the wiring in switch box consists of grounds tied together, 2 whites...
you got the wires you need. add switch's white to the white bundle in the back; green to grounds, red to the black going to the light; black to the other black. worked for me!
Jan 29, 2011 | Computers & Internet
I the manual wiring doesn't match what I have in the switch box. This switch is to operate 2 outside porch lights., previously wired to a single pole switch as follows.. one black wire to one screw and 2...
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Dec 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Trying to replace Intermatic with Utilitech inwall timers. Have 2 black wires in wall box with other switches for other lights. Which of the Utilitech 4 wires- black, red, white & green get conected to...
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Apr 08, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
GE 60minute Automatic ShutOff Timer Switch   15069 Logo
517 people viewed this question
Top GE Hardware & Accessories Experts
George Nalley
Level 1 Expert
Paul Bade
Gene Haynes
Are you a GE Hardware and Accessory Expert? Answer questions, earn points and help others
