Question about Sony Walkman NWZ-B142 MP3 Player
My mp3 player plays my music but its just a white screen i cant select anything in particular its just blank white
  • Sony Master
  • 1,606 Answers
It's possible that the display contrast is mis-adjusted, but the Sony website does not have the user manuals posted online in English (and if I read it correctly, they aren't available in Spanish either - my Spanish is very limited, and my knowledge of Portuguese is based on guessing from similarities to Spanish and Latin), so I cannot check whether this unit has adjustable display contrast. If you have your manual available, look for the instructions to reset the unit back to factory defaults. This will probably also erase all of your music, so save a backup copy first.
If that doesn't work then:
Best case, assuming the problem isn't a low battery voltage leaving the LCD driver chip inoperable: the connector between the LCD panel and the main circuit board has come loose or has a bad connection to the panel's backplane conductor.
Bad case: the LCD driver has failed. (Replacement requires surface mount soldering expertise and equipment; may be a hard-to-find proprietary chip.) It is also possible that there is a cracked circuit board; this may be repairable without buying parts.
Really bad case: the LCD panel is broken. (Hard-to-find part.) Usually this is visible breakage, which you don't mention.
Try gently flexing and squeezing the unit, but be very careful not to apply too much force to the LCD either directly or with the bending case top. If the display shows, even briefly, then you know it's a connection problem. LCD panels generally are connected edges, so try a little pressure on the case right next to the display.
Post back if you want to dig around inside for the problem. If it's still under warranty, collect on it. Note to other readers: according to Sony, this model is available only in Latin America or Brazil.
Posted on Oct 13, 2010
I cant see the words nmy hp appe ipod screen!
I have had this problem recently myself and would like you to know that it is possible to fix. The white screen error or otherwise known as "white screen of death" is caused by the lcd color screen on the ipod itself. That is why its functions still work but the screen does not. Once you replace the color screen it will be as good as new.
Nov 15, 2008 | Appel Apple iPod from MP3 Player
Screne is white
you ahve to get a toothpic and stick it in the reset hole.
mine went like that too but the screen was blue and now that i reset it, it works as good as new =]
but is wont delete anything.
Oct 16, 2008 | Creative Labs Zen Digital Media Player
Creative Labs Zen Micro White MP3 Player
Sounds like you need to buy a new screen. They are $9.99. Click here
Oct 09, 2008 | Creative Labs Zen Micro MP3 Player
White Screen
if you disconnect your mp3 player, does the screen still appear white and can you turn it on or off?
i had the same problem, basically it freezes because it is busy downloading music or placing music where it is suppost to be. but if you cannot turn it off after you have unplugged it, you should take off the back cover and take out the battery. place the battery back in, and replace the cover and it should be able to turn back on without a white screen.
Sep 10, 2008 | SanDisk Sansa E280 MP3 Player
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Try the Five R's suggested by your user's manual - you can get the manual from Apple's website if you have lost it:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Jun 14, 2008 | Apple iPod nano 2nd Generation MP3 Player
Sansa MP3 Screen is white - display not working
1. Try resetting the player if it has a reset button
2. Drain the battery by leaving it on for an extended period until the screen in blank and no sound comes out of your ear buds. Then connect to AC adapter or computer and charge.
Feb 27, 2008 | SanDisk Sansa e260 MP3 Player
Mp3 player problems
That has worked on previous MP3 players forme but i've never had that problem with my Insignia. You might try the reset button as well.
Feb 20, 2008 | Insignia NS-DV2G MP3 Player
Mp3 music plays but
The Opal has a reset hole on the back of the unit in which a toothpick (non metallic) can be inserted to reboot the player.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
  1. Right click on the device within the Explorer or My Computer window
  2. Select the format command (full format) to reformat the internal memory of the device.
  3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Sep 21, 2007 | RCA OPAL M4001 MP3 Player
Sony Walkman NWZ-B142  MP3 Player Logo
263 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
