Question about Nintendo GameCube Console
First time instructions(overall) 4 the game cube!
The paper work u recieve when you buy the game from a store!
id like to get it in the mail or be able to down load it to my printer
Thank U!
  • 3 Answers
Try to locate the file online. it is the best i can do.
Posted on Jun 01, 2008
Following instructions from something, i totally uninstalled my playstore app. And my gmail. Please help.
https://play.google.com/store/apps/details?id=com.google
https://support.google.com/mail/?hl=en
hope this helps.
Jun 10, 2014 | Facebook Apps
Every time i play a particular part in legend of zelda twilight princess it says'an error has occurred please switch off the system and check the gamecube instruction' or something of the like, I don't...
Well if the disc has scratches on it then the GameCube will have a hard time reading the discs then. So buy a new game cube game then for that lukie games
Dec 26, 2010 | Nintendo GameCube Console
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do i save a game cube game on the wii
u have to buy a game cube memery card. see at the top of the wii there r these sockets 4 circulars and 2 rectangles the rectangles r for the memory card
Oct 06, 2009 | Video Game Consoles & Games
I have 2 nintendo game cube and they out of 20
If each system will read different specific games, then its the systems. You can get them repaired, but they are honestly so cheap now that you would actually be losing money by not just replacing one (pretty sure it still works out alright for two, just not sure).
Aug 04, 2009 | Nintendo GameCube Console
Gamecube, output problem.
There is no way to switch this back and forth, if the rca jacks work and the fr jack doesnot there is a problem extending from the game unit itself which works on a certain amount electrical current to maintain signal which is not required for digital/rca. check your rca connections, if they work then your problem is in the rf converter and it should be replaced and or just purchase a cheap switching unit that splits between the rf and the rca on channels 3 or 4. Good Luck and let me know what happens.
Fehdi
Jul 14, 2009 | Nintendo GameCube Console
Recieving Email
Check your yahoo mail id properly. Go to the 'My account" page and confirm your mail id whether its yahoo.com or yahoo.co.in or yahoo.co.uk or whatever. Then try sending to the right mail id which will let you recieve mails.
Thanks.
Nov 02, 2008 | Yahoo Mail
Are Nintendo game disc backwards compatible with the game cube?
No. The gamecube discs are more the size of a minidisc and the ones for wii are full size discs like a DVD. My son is also 6 (going on 7 of course!) I decided to take the plunge after a long time battling with this decision. I just put the wii up high so he gets my help to load/change discs. He LOVES it! He is so great at it too! He loves the WiiSports, which the console comes with. (He even beats me at bowling!) It's a fun set up. I love that there are many games we can play together as a family, Cranium Kadooi, WiiSports, Playground, SmartyPants, as well as Active Life is due out soon and that looks to be awesome for some indoor activity! It is hard to make the decision to spend that much. I have been hanging onto the idea the last 2 years, that the price would drop and I would buy it then. Well, the price does not go down. In fact, it's hard to find at the retail price as it is hard for the stores to keep on the shelf! Good luck with the gamecube. If you still aren't ready to switch, maybe just let him pic out a few new games. This is sure to renew his interest in Gamecube! AS it is hard to find gamecube games in stores new, definately look on ebay.com for new and slightly used (which are great buys and I've never had a bad experience) gamecube games. Barnyard is a super cute one!
Please leave me a great rating if you found my reply helpful. Thank you! :)
Aug 13, 2008 | Nintendo Wii Console
Game Cube remotes for Wii
Hi, on the top of the Wii will be a hidden flap which conceals 4 gamecube controller ports. You will need to buy a memory card which there are two slots for that to store the games. Gamecube memory cards are quite cheap and you can pick them up for between £2 to £10. Hope that helps.
Apr 28, 2008 | Nintendo Wii Console
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Nintendo GameCube Console Logo
26 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
