Question about LG 50PC3D 50 in. Plasma Television
My lg 50pc3d has sound but no picture. There is a loud buzz that seems to be coming from the plasma panel itself from everywhere. i checked the 3 fuses and tested the voltage on the power supply board, proper voltages and fuses good including the surface mount one. The buzz is like an oscillating sound. when I turn on the monitor I see the leds on the board kinda flashing with the oscillating buzz. any help would be great
jerryg50
  • 1689 Answers
SOURCE: 50 in LG turns on and then clicks and turns back off
The power supply is going in to protect mode. Most often this is a power supply failure, or a failure on one of the circuit boards that is causing the power supply to go in to protect.
If the power supply fault is not too complicated an experienced tech may be able to service it without changing the compete circuit board.
The tech will service this by substituting boards to determine where the failure is occuring. Then he will change the board to fix the fault.
Jerry G.
Posted on Feb 10, 2009
SOURCE: LG 42PX4MVH PLASMA TV - Sound but no picture.
I have the same issue with my LG 42PC3DVA and I narrowed it down to the Y SUS board. After a little research there are a few items that are prone to go. The ceramic fuses (as you found), sometimes the capacitors on the Y SUS, Z SUS, and power supply go along with them You can tell because thy will be bulged at the top instead of flat. I replaced a few of my capacitors - they are only $0.89 each so it was MUCH cheaper than a board.
The other thing that is common on the Y SUS in particular are the FETs (also called MOSFET). They can be replaced if you are good with a soldering gun but they are static sensitive so be grounded. They are also a bit tricky to test so you may want to do some research on how to determine if this is the issue... or you can just replace the whole board.
Posted on Oct 28, 2009
  • 380 Answers
SOURCE: to make a long story short originally bought the
Sounds like the y sus was blown out but what cause it. Were you careful when you were checking voltages? As long as you didn't short 2 components together, your y sus should be fine. Unless the y buffer up and/or down blew them out. Even the panel could blow it.
Basically you need a scope to adjust the ramps and everything. You can adjust VA and VS with a meter. If you don't have access to a scope, then just start changing the ramps etc by eye. It might take a little bit to get but eventually you'll get it.
Posted on Mar 14, 2010
SOURCE: LG RT-42PX10 plasma - No Display
Power supply on left hand side module. check if heatsinks are cold. possible faulty. fuses and input voltages first check.
Posted on Apr 07, 2010
SOURCE: while checking Vscan voltages on my LG du-42px12x picture died.
I have the same problem the pic went out but have sound. where do i go to get the Yboard? do i need a special number off of it or something? I took it to repair shop and he said it would be like 500 dollarss to repair. but i see all kind of yboards on ebay for like 150?? how do I know what one to buy?
Posted on Aug 08, 2010
I have Lg 50pc3d-ud and it has very dark spots on the tv that moves around. The screen is also very dark no matter the settings. The dark spots aren't always there, they go away sometimes but if...
This problems ur tv are having only can be two causes 1) The Y-Sustance main tuner logic board or 2)The tv Plasma screen panel itself it is slowly leaking radiaton and dying,if it is the tv plasma screen panel itself it is dying than the tv not worth repairing because by replacing the plasma screen panel itself will cost the same as a new tv itself.The Y-Sustance board-that the tuner main logic board that take in the tv incomming broadcasting signal cable.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish Y-Sustance main tuner logic board for replacement.This tv problems are 50/50 between the Y-Sustance main tuner logic board or the very exspensive plasma screen panel itself.
Oct 27, 2011 | LG 50PC3D 50 in. Plasma Television
LG 50PC3D capacitors bubbled on the powerboard. Ordered original powerboard #6709900020B, was sent a CRB30626401. Installed the new powerboard. The powerboard comes up now and stays but no picture. Is...
Not familiar with your set but check for a separate, smaller power supply board or module that services the display itself. Plasma sets require a high voltage for operation and if it failed, it could cause the failure of the main supply from which it often receives its input DC. Since the plasma service voltage isn't always the same from one set to the next, can't give you specific levels to look for but it will be high enough to cause serious pain; use caution.
Sep 24, 2011 | LG 50PC3D 50 in. Plasma Television
LG 50PC3D very loud pop, screen went 95% black and of course still have sound. does this sound familiar? michael
check the capacators on the main power board if they are not popped more than likely it is either the z or y sustain boards
Feb 28, 2010 | LG 50PC3D 50 in. Plasma Television
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
No picture, but still displays light
Sounds like a dead screen you'll need to get it repaired. Check if it is still in warranty.
Jul 07, 2009 | LG 50PC3D 50 in. Plasma Television
LG 50PC3D w/no picture
Your mainboard is damaged, replace it and that will solve your issue.
Jun 05, 2009 | LG 50PC3D 50 in. Plasma Television
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 50PC3D 50 in. Plasma Television Logo
177 people viewed this question
