Question about Vacuums
I need the manual for rhe rival steam iron Model # IR603
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I need the operating manual
Here is the manual
Posted on Aug 06, 2011
Build up of deposits when steam iron is used, how do you get iron apart ?
You might be able to clean out your steam iron by putting vinegar in instead of water. It has worked on my steam iron as well as my coffee pot.
Jun 26, 2011 | Vacuums
How do i descale a SWAN iron model no S15030N. CAN I PUT DESCALER INTO WATER STORAGE TANK
The best and cheapest way to descale irons,steamers, etc. is to use white vinegar, mixed 1 cup to a quart of water. Pour in the iron and allow to steam. The vinegar will dissolve the calcium, which is the blocking scale. Do this a few times toensure that the holes are clear and operating correctly. For the last rinse, put a little lemon into plain water and allow to steam. This gets rid of any vinegar smell.
Jun 09, 2011 | Vacuums
I need instructions on how to clean Digital Advantage Iron. I have lost my manual.
any iron can be cleaned by running a little water and vinegar through it several times, it loosens the scale build up that gets in all irons over time, be sure and try to clean out the venting steam holes in the face of the iron, Once you do this, run clean clear water through it and you should be fine, if possible, always use bottled water (purified) water in irons
Jun 02, 2011 | Vacuums
I have a stirella dual steam iron. At present it is constantly steaming even though the steam button is not clicked in place. How can I fix this?
It sounds like the steam valve inside the iron is stuck open. You have to take the iron apart and free it up by lightly scraping water deposits off it with a screwdriver.
Mar 16, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Do you have a manual for a Sunbeam Steam Iron Model 48Z6 - E91117
Sadly, the manual referenced above by link appears to be no longer available. I'll keep looking. Thanks
Sep 17, 2010 | Vacuums
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro Steam Iron Mod. 4488
My 4488 euro steam will not heat up?? All connections etc have been cut and reconnected. Power light is on! Any ideas????
Apr 10, 2008 | Vacuums
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
