Question about RCA P52926 52" Rear Projection Television
A yellow line around images and certain parts of screen
  • RCA Master
  • 8,457 Answers
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergnece board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 13, 2010
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung big screen tv, the color is off, it was dropped
IM NOT OF YOUR TV TYPE BUT IF THERE IS A TUBE IN THE INSIDE OF THE SET BUT BEHIND THE SCREEN, ON THE EXTENSION OF THE TUBE THERE SHOULD BE THREE OR SIX TABS LINED ONE IN FROUNT OF THE OTHER CONNECTED OR PART OF A CIRCULAR PIECE FITTED AROUND THE EXTENSION.SIMPLE ROTATE THEM AROUND THE EXT UNTIL THE IMAGES LINE UP, THIS NEEDS TO BE DONE WHILE POWER IS ON SO BE VERY CAREFUL NUT TO SHOCK YOURSELF
Feb 11, 2012 | Samsung Televison & Video
I have a Hitachi 60sdx88ba UltraVision Digital Projection TV @ the top of the screen a yellow swoosh 6 inches wide with a blue line 8 inches under it. On the right bottam a 3 appears. Double image on the...
You have a defect in the convergence circuit. Both chips will need replaced and possibly a resistor or two. Chip part numbers are STK392-110. Typical repair runs around $350
Bill W
integrityhomeworx.com
Mar 20, 2011 | Hitachi 43UWX10B 43" Rear Projection...
I have a bizhub C450 and i am getting a yellow line at the top of my printed page and also 2 pink/red dots in the middle of the page. How can i stop this?
The yellow and magenta image units may be the problem. Yellow may have worn out on one end causing the yellow line. If the pink dots show up on every page but move around from page to page, there may be damage to the magenta image unit. You can remove the image units from the machine and look at the drums (long green cylinders), this should be shiny and clean. If not, you may need to replace.
Apr 28, 2010 | Konica Minolta bizhub C450P Laser Printer
Color dots on tv
u have a bad optical block , this part is very costly , but call sony costumer service , u tv maybe onder recall because of this problem
Apr 15, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Panasonic PT-61LCX65 61 -- Neon Yellow Lines
I called Panasonic and they are sending a repairman. My TV is 3 years old. They said they'd cover the repair as a one-time in-warranty even though it is out of warranty because they've been having problems with this model. Don't do like me and try to live with the problem.
Good luck to all that have this problem.
Sep 14, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
NEc plasmasync 42mp2 - dark screen and in the top few pixels show the image
It's either the Y-main or logic board but you would need to do some extensive testing to know for certain which one... It's not the screen..
I would strongly recommend you take it into a shop and have a Tech test it and give you an estimate..
Bill
Nov 17, 2007 | NEC PlasmaSync 42MP2 42 in. Television
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
