Question about American Standard Home
Can't find actuater disc for 1972 american standard toilet number 4052-66
djchillsnyc
  • 151 Answers
SOURCE: have to flush 2 or 3 times to empty toilet bowl
hello, this is a standard toilet you will need to inspect the flapper that is the rubber flap that holds the water up in the tank it works when you pull the lever it pulls the chain upward and lets the water flow if this flapper is old it may not stay up long enough for the water to flow. open the tank top and flush the toilet see if this flapper is staying up long enough and giving the tank enough time to empty if not change this rubber flapper its inexpensive part.
if this is not the reason then you need to adjust your water filler valve there should be a small screw on top of the pivoting float arm
if you have to adjust it for the water limit line inside the tank this will be the proper amount of water needed to flush once completely
also check that the chain lenth on the pull lever is not pulling the flapper down quicker than its supposed to,
try this let me know your results
hope it helps
Posted on Dec 15, 2008
co7196
  • 3433 Answers
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
Posted on Jun 20, 2009
  • 9 Answers
SOURCE: hole in back of toilet (stool) leaks water.
The hole your refering to is common in the manufacturing of toilets and is generally filled before it leaves the manufacturing. I have repaired several toilets, new toilets, all American Standard, using a good grade of epoxy - not silicone. I used West System epoxy as this is made for marine projects and surprisingly states "toilet repair" as one of the uses of their product. I'd suggest carefully chipping the smooth porcelan around the hole to give the epoxy something to grip. Use a knife or screwdriver to gently chip the edges and make sure the area is dry. Press the epoxy into the hole and give it enough time to cure before putting it back in service. Of course, if the toilet is less than a month old I suggest returning it and getting a new toilet.
Posted on Jun 22, 2009
  • 54 Answers
SOURCE: American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Posted on Sep 26, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
Where can I buy the toilet seat hinges for an american standard plaza elisse
Go to American Standard website for customer assistance phone number.
Sep 26, 2013 | American Standard Church Seats EL270...
Need to replace toilet seat and cover for a Williamsburg, white toilet. The part number I have is 5395.700.....but I have learned this number no longer exists. What number toilet seat/cover fits a...
Your toilet is still offered by the manufacturer:
http://www.americanstandard-us.com/toilets/williamsburg-one-piece-elongated-toilet/
Available replacement toilet seats from American Standard can be seen and ordered here:
http://www.americanstandard-us.com/repair-parts/toilet-seats/
You might consider finding you nearest dealer or choose another on-line retailer:
http://www.americanstandard-us.com/dealerLocator.aspx
Before ordering suggest you confirm with American Standard Customer Service the appropriate replacement seat for your model.
http://www.americanstandard-us.com/customerservice/onlineStoreSupport.aspx
Mar 15, 2011 | American Standard Williamsburg Toilet Seat...
What does a toilet actuator do?
Older American standard toilet have an actuator in place of a flapper. it looks like a big black thing with a round tube on top that the chain attaches to, when you flush this toilet the actuator seams to lay on it's back for a few seconds and then drops back down, and the tank refills.
Nov 04, 2010 | Eljer Aqua-Saver Toilet Actuator -...
Replacing my toilet's seat disc
http://www.americanstandard-us.com/customerservice/Care/TroubleTreeDetail.aspx?TopicID=2&Depth=2&AnswerText=Two-Piece%20Gravity-Fed&QuestionID=107&ModelNumber=&ProductType=2-Piece%20Gravity&ProductName=
Follow the link above, it will probably answer any questions you may have for your particular toilet. They are all different and without the model number, it's hard from my point of view to understand what you may need. Hope this helps you!
Mar 21, 2009 | American Standard Home
Need to replace working parts , push button , one piece toilet
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
Jan 27, 2009 | American Standard - Lavatory Faucet -...
Square toilet seat made by American Standard Model TL 235.
This guy Allen in NY has lots of odd seats. Try him 914-963-6895
Jan 06, 2009 | Home
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
79 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
