Question about Hampton Bay 52 In. Sussex Fan, Ancient Bronze
Lost locking nut for globe where can i get one?
Have tried all suggestions to remove globe to change bulbs.....nothing works. Help
There should be a nutcap at the bottom of the finial that holds the globe in place. If not, then three set screws around the top of the globe need to be loosened. If the finial turns as well, you should be able to unscrew it all the way out, then you will have to reattach it and use a nut to tighten it up so it doesn't turn in the future.
Apr 25, 2017 | Dryers
How do I remove wheel Lock nut on 1999 Isuzu Trooper if lock key has lost?
we cant see it of the 100s made.
go to any tire./wheel store and ask them to fix this.
or drill yours out. (some you can, no photo no joy here)
Aug 17, 2014 | 1999 Isuzu Trooper
I cant get my lug nuts off i lost the locked key
Most of the lock nuts are made of normal steel so get a socket that will "just" not fit and drive it on the nut well . Talk with a tyre shop as they use this process on a regular basis to remove tyres for people who have your problem. Use a bar or rattle gun and the nut will come off . Replace all the lock nuts with units that you can get a lock nut adaptor for
Feb 09, 2014 | Chrysler Cars & Trucks
Lost wheel locking nut oval/round head type for my jaguar x type please advise where to get one from
http://www.incarshop.co.uk/acatalog/Jaguar_X_Type_Locking_Wheel_Nuts_and_Bolts.html
In Car Shop has Jaguar X wheel locking nuts for sale. They offer both aftermarket and OEM replacement locking nuts.
Mar 25, 2011 | Jaguar X-Type Cars & Trucks
Lost locking weel nut with a puncture how do i change it???
Depending on locking nut type.
If it's like mine, having a recessed "clover leaf channel" then you can only weld something to it like a bolt, if its an alternative nut type I.E. star or some other shape with edges, you can hammer a cheap socket over it and try that.(once the socket is shaped you can usually remve the rest and replace with new ones)
May 24, 2009 | 2001 Ford Focus
HOW CAN I UNLOCK GLOBE SIM CARD PUK CODE?
HI.
for your puk code you will need to contact your sim network and ask them for the puk code there the only one to have this .
dont enter any other number till you have your puk code for sim network.
riz.
Jan 31, 2009 | Cell Phones
How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Dec 29, 2007 | Dryers
Hampton Bay 52 In. Sussex Fan, Ancient Bronze Logo
174 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
