Question about Fisher Paykel EcoSmart GWL15
This Fisher & Paykel GWL15 washer began making strange noises this week. When the water is pumping out, a loud, moaning or grinding sound is made. It also makes the sound after a few minutes at the beginning of the initial fill. Any suggestions? Thanks!
Same thing happened to mine. There's a really simple solution: Lay the unit on it's back or lean it far enough back to have access. The pump is near the front and has a black fan blade on the bottom. Remove the electrical plug on the motor; it just pulls right off. Now look for a white plastic retaining lever near the top of the pump. Hold it out and turn the pump about 1/8 turn counter-clockwise, then it almost falls out. I found a safety pin inside that was causing my noise. Went back together just as easily. Problem solved!!!
Posted on Jan 25, 2011
  • 2 more comments
  • ridehist Mar 17, 2011
    Thanks! I tried that and got 'er going again. And would you believe that after I cleaned it, put it back together, and ran an empty run, there was an open safety pin and wad of lint in the bottom of the tub? Really!! Thanks
  • spreadeagle Mar 18, 2011
    Hey ridehist, You're welcome!! I'm thrilled that I was able to help someone else. This is a great site for sharing information. I will definitely check here again when I have another problem.
  • tndrawde Apr 24, 2011
    Do you know where I can get a Troubleshooting guide and/or Error Code List for the GWL15 US?
  • spreadeagle Apr 25, 2011
    I don't have any special access to that info. But, I did a google search, and there are a lot of posts out there about this washer. Everything from how to get the error codes from the washer to what they mean. If you need some more help, send me some more info including your error code and a description of the problem and I will try to help.
I have a fisher and paykel washer and it keeps giving me service fault 130. Does anyone know what this means? My washer will not work at all. Please help!!!!!!!!!!!
Posted on Apr 25, 2011
My GWL15 Washing machine completely died with a couple of inches of water left. Is it the motor? This machine is non responsive.
It could be the pump that has blown the fuse on the board,
Was the pump making loud noise at the time when it died.
if so replace pump and fuse.
Sep 03, 2013 | Fisher Paykel EcoSmart GWL15
Fisher&paykel washer will not turn on at all. Is this the main circuit board
Yes it is the board dead.
Some common cause is the pump or water in the wrong place.
Get a technician to replace these parts.
Aug 11, 2013 | Fisher Paykel EcoSmart GWL15
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
Pump does pump but makes noise. I suppect it has
The pump is on the bottom. It has a locking tab you release, then you twist the pump a quarter turn and she drops out the bottom.
May 25, 2010 | Fisher and Paykel WA37T26G Top Load Washer
I have a Fisher & Paykel GWL15 and I have not found what is making the squilling noise when the washer starts to fill and when it is in the rinse cycle. I previously was a appliance repairman and in GE...
More likely to be the pump. Right after it lets water in it recirculates the water. To find out start the cycle. When you hear the noise, disconnect the wires going to the pump and see if it stops. The pump is on the bottom. To get to it just tip the machine back.
Nov 30, 2009 | Fisher Paykel EcoSmart GWL15
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Fisher Paykel EcoSmart GWL15 Logo
1,686 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
