Question about Mitsubishi CS-40503 TV
Our TV will suddenly lose sound and picture. I can still hear it click on and off, but nothing else. If you leave it off for a while the picture will come back for a little bit but not for very long (15 minutes). If it is left off for a day or two, the picture and sound will stay on for about an hour before going out again. It doesn't seem to have any other problems.
  • Kyle James Oct 13, 2010
    I already have the TV in a position where the back could be removed and my father has a lot of soldering experience (I have a little). I'm the type of guy that will refurbish an electric motor myself before buying a new one. I also replaced the engine block in my Acura to avoid buying a new car or paying someone else to do it. I think that removing a board and fixing a couple of solder connections sounds like great news!!
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
First: I worked on a lot of these sets. They were expensive when new and were very good sets.
If set will work when not used for a while for a hour you have a soldering problem. What happens is the boards were not soldered by hand, they were soldered in a single motion. After years of use as board expands and contracts when hot and cold, bad solder connections develop.
I strongly suspect you have some bad solder connections now. The hard part with this set is it is so heavy and large you have to get the back off and get the board loose to examine the bottom. Once you have it in this position you look at the bottom carefully and bad connections will be clear to see--I fixed dozens of them (one given to me) and average time with board up is under a hour.
How much skill do you have and what are you willing to do?
The more you tell me the better I can help you.
SD TECH
Posted on Oct 13, 2010
  • SD Tech
    SD Tech Oct 13, 2010
    look carefully at power supply part of main board to the right as seen from back of set.
I have an LG smart tv model no. 42LV3730-TD- standby light flashes blue once then it goes red again then nothing.i hear a clicking noise from the back of the tv but that's it. No sound/picture nothing.can...
In most of the case, the problem is a defective main digital board (component loses connections on board). you may try this at your own risk:.
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 31, 2017 | LG Televison & Video
Heard a pop when I turned on tv and now nothing
don't leave it on and have it looked at---most likely is if it uses a lamp that may be the problem but if not it may be in the power supply.
May 20, 2012 | Sony KDF-E55A20 55 in. LCD Television
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
Heard clicking sound then pictures suddenly disappear and the tv keeps turning off and on by itself
The tv have a board call the Ballast board,that help to ignite the projection lamp.Tv power on hear alot clicking.That mean the Ballast board is dead,must be replaced.
Jul 13, 2010 | Samsung HLP5085W 50" Rear Projection...
Nothing comes out just blank screen
if you can hear sound it is the backlight invertor needs replacing
May 21, 2010 | Samsung PN50C450 50 in. TV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
52" plasma tv - turns on - and I hear something reset inside
i hear a clicking noise- the clicking noise is most likely you ballast trying to power the lamp, but failing. this may indicate a defective ballast if you have recenty purchased a new lamp.I recomend you have your lamp tested to help narrow down the cause of the defect. It's highly unlikely for a new lamp to be dead on arrival
Dec 04, 2008 | Dell Televison & Video
Can't get anything on the screen
Unplug the power cord from the TV set and leave it unplugged for 5 minutes. Plug the power cord back into the TV and turn it on. It should work. This is not an uncommon problem for the Akai line.
Nov 02, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
No picture, but power light is on
THE POWER SUPPLY OF YOUR TV WAS THE PROBLEM,YOU COLD SOLDER THE MAINBOARD OF YOUR TV,AND THE CRT SOCKET CONNECT TO THE TUBE IS ALSO COLDSOLDER,.
Mar 13, 2008 | RCA 27F530T 27" TV
Samsung TXM3296HF problem - tv won't turn on
your flyback transformer could be your problem or in the video circuit.have a tech look at your tv for possible repairs.good luck.
Apr 01, 2007 | Samsung TXM3296HF 32" TV
Televison & Video Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
