Question about Lexmark P3150 All-In-One InkJet Printer
Can i use print cartridge 70 or 12A1970 for printer lexmark P3150
    Genius:
  • 1,087 Answers
#70 cartridge is not compatible with the Lexmark P3150 printer. Compatible cartridges for your printer available in the Lexmark website at http://bit.ly/9DTsPt. Thanks.
Posted on Oct 13, 2010
Belt repair for lexmark p3150 print trio multi-function
If you need lexmark customer support number 1866-877-0191.We are always here with tech team for your help. For further Info Click On Me:https://goo.gl/hvj3MK
Mar 11, 2012 | Lexmark P3150 All-In-One InkJet Printer
My lexmark 3150 printer will not print anything in color even though the refill color cartridge is completely full
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. But if that doesn't help, I would suggest that you replace it with new genuine Lexmark cartridges.
Aug 26, 2011 | Lexmark P3150 All-In-One InkJet Printer
I have a Lexmark P3150 printer. It worked fine last time I used it but it has been several months since I have used it. I am now trying to print and cannot get it to print either in black or a color. I...
Your ink cartridge nozzles may be clogged. You may try to do a cleaning cartridge nozzles cycle.
Open the Lexmark Solution Center. Click on the Maintenance tab. Click on Clean to fix horizontal streaks. Click on Print. Depending on the diagonal lines results, you can click on Clean Again.
Jun 05, 2011 | Lexmark P3150 All-In-One InkJet Printer
How to install the ink caridges in the printer for black, color and photo ink cartridges?
Perhaps the Lexmark P3150 User's Guide will be able to help you. Click on the link to download: http://bit.ly/bk5IRX. Scroll to Maintenance, Page 38, for instructions on how to replace/install the cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Sep 21, 2010 | Lexmark P3150 All-In-One InkJet Printer
P3150 will not print black,has a new cartridge and have tried all the tricks on the cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 25, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150
Some people have success with varying brands of generic carts, some don't. You can try copying many pages of anything many times. say 50, then run head clean routine. Repeat up to 250 copies. If after this still white pages, get genuine carts and repeat until it works. If no go the head is probably clagged up with generic ink. Then you need to pull it and soak, but don't hold your breath.....
Apr 27, 2009 | Lexmark X3350 All-In-One InkJet Printer
P3150 printer runs but doesn't print
Are you saying that the printer prints in B&W but not in color, or only that it will print a test page with B&W? It might be that the color ink cartridge is dry.
Apr 20, 2009 | Lexmark P3150 All-In-One InkJet Printer
Cartridge number for lexmark P 3150
#90 --> OEM Photo colour Ink cartridge (Lexmark 12A1990)
#20 --> OEM Colour Ink cartridge (Lexmark 15M0120)
#50--> OEM Black Ink cartridge (Lexmark 17G0050)
**OEM stands for: "Original Equipment Manufacturer
Hope this helps and please don't forget to give my answer a rating!
Thanks,
OpenSource13
Apr 06, 2009 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Oct 04, 2008 | Lexmark P3150 All-In-One InkJet Printer
Nothing prints
Actually, yes there are compatiblilty issues with Lexmark's drivers and Vista.
Here is a forum from microsoft about this issue : Click Here
Basically if you do not want to downgrade from Vista or wait for Lexmark to release drivers (P3150 is a discontinued printer and will probably not have another official driver release) or you can add your P3150 and select 'Generic / Text Only' for your driver and set the correct port (USB, Parallel, or however). But that will not use all the great features your printer comes with especially because it is an All-In-One as opposed to someone who just wants to print documents.
Hope this solved your problem.
Jan 16, 2008 | Lexmark P3150 All-In-One InkJet Printer
Lexmark P3150 All-In-One InkJet Printer Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
