Question about Healthometer Health o meter BFM883DQN 01 Body Fat Scale (Health O Meter)
How do i switch from kg to lbs? - Healthometer Health o meter BFM883DQN 01 Body Fat Scale (Health O Meter)
How many lbs are 105.9 kg?
Hello;
My name is Peter. I am a engineering college graduate.
Kg x 2.20462 = Lbs. or 105.9 Kg. x 2.20462 = 233.5 Lbs.
Mar 13, 2015 | Cars & Trucks
Conversion from kg to lb
Multiply by 2.2 to get lbs. In this case, 84 kg should convert to approximately 184.8 lbs.
Aug 19, 2014 | Cars & Trucks
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
How much air pressure to put in shocks with 2 riders
2006 Touring shocks =
Table 2-6. Rear Air Suspension Pressures
Shock Loading Recommended Pressures
PSI kPa
All Models Except FLHRS, FLHX - Standard Shocks
Solo rider up to 150 lbs. (68 kg), hereafter referred to as "Average" 0 0
Solo rider 150-200 lbs. (68-91 kg) 0-10 0-69
Solo rider 200-250 lbs. (91-113 kg) 5-15 35-103
Average rider with passenger up to 150 lbs. (68 kg) 10-15 69-103
Average rider with passenger up to 200 lbs. (91 kg) 20-25 138-172
Maximum GVWR (see Section 2.1 Specifications) 20-35 138-241
FLHRS, FLHX Only - Low Profile Shocks
Solo rider up to 160 lbs. (73 kg), hereafter referred to as "Average" 0-5 0-35
Solo rider 160-200 lbs. (73-91 kg) 0-10 0-69
Solo rider over 200 lbs. (91 kg) 5-10 35-69
Average rider with passenger up to 150 lbs. (68 kg) 20-30 138-207
Average rider with passenger over 150 lbs. (68 kg) 25-35 172-241
Maximum GVWR (see Section 2.1 Specifications) 40-50 276-345
111WWAARRNNININGG
Use this table as a starting point in determining suitable rear air suspension pressures. Do not exceed
maximum GVWR when loading vehicle and do not pressurize system in excess of 50 psi (345 kPa) for
FLHRS, FLHX models and 35 psi (241 kPa) for all others. Excessive load weight and/or air suspension
pressure can adversely affect handling and lead to loss of vehicle control, which could result in loss of life
Aug 30, 2011 | 2006 Harley Davidson FLHR Road king
How to convert from kg to lbs on the defrost cycle
.45 kg = 1 lb
2.22 lbs = 1kg
So if you know kg and need lbs. multiply the number of kg by 2.22. for example if you have 4 kg
4 x 2.22 = 8 lbs
May 10, 2010 | Panasonic NN-H275 Microwave Oven
How to remove oil pan from 2003 kia spectra
REMOVAL
1. Disconnect negative battery cable.
2. Drain engine oil
3. Remove LH and RH side splash shields.
4. Remove front exhaust pipe.
5. Remove oil pan mounting bolts.
  1. Remove oil pan with screwdriver or suitable tool as shown in figure. Caution:
a) Do not force tools between cylinder block and oil pan because this may damage sealing surfaces. b) Do not damage sealing surfaces when removing old sealant
  1. Remove oil strainer.
Replacement
Caution:
a) If oil pan is reused, remove all foreign material from sealing surfaces of cylinder block and oil pan. b) If bolts are reused, remove old sealant from bolt threads.
  1. Install oil strainer. Tightening torque: 5.8 - 8.7 ft. lbs. (7.8 - 11.8 Nm, 0.8 - 1.2 kg-m)
  2. Apply a continuous bead of silicone sealant to baffle plate along inside of bolt holes on contact surfaces. Caution: The oil pan must be installed no longer than 5 minutes after silicone sealant is applied.
3. Install oil pan. Tightening torque: (A) (B) (C) (D): 5.8 - 8.0 ft. lbs. (7.8 - 10.8 Nm, 0.8 - 1.1 kg-m) (E): 28 - 38 ft. lbs. (38 - 51 Nm, 3.8 - 5.3 kg-m)
4. install front exhaust pipe. Tightening torque: (A): 29.7 - 40.5 ft. lbs. (40.2 - 54.9 Nm, 4.1 - 5.6 kg-m) (B): 51 - 69 ft. lbs. (69 - 94 Nm, 6.9 - 9.4 kg-m) (C): 15.2 - 20.2 ft. lbs. (20.6 - 27.4 Nm, 2.1 - 2.8 kg-m)
5. Install LH and RH side splash shields. Tightening torque: 12 - 18 ft. lbs. (16 - 24 Nm, 1.6 - 2.4 kg-m)
6 . Fill with specified amount and type of engine oil.
GOOD LUCK,I HOPE THIS HELPS...
Jun 04, 2009 | 2003 Kia Spectra
How do you change the weight settings from kg to lbs
I don't know if you can change the setting but 1 kg is 2.2046 lbs so 100 kg would be 220.46 lbs for example. Multiply kg times 2.2046 to get lbs
Mar 08, 2009 | Nintendo Wii Fit for Wii
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Healthometer Health o meter BFM883DQN 01 Body Fat Scale (Health O Meter) Logo
69 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
