Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
My refrigerator's inner fan was making weird noises. After some time I poked it and then it stopped moving. The fan is now unable to turn. What should I do?
Two things could be wrong. Motor bad or frozen up with ice.The noise could have been
from frost building up and hitting the fan.If this is the case you need to defrost. Even self
defrost models do this some times..Empty freezer and run a hair blower (dryer) to put heat
in the compartment. this could take a while to do. over night...So run blower for a while to heat up the freezer then shut it off, close door .let sit It takes time for the heat to get to the ice.
if the motor is bad you will have to take inside cover off the access the motor
Posted on Oct 13, 2010
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
How to access service Menu on Samsung Refrigerator 26Cf French model RF261 BEAE
look on the internet for a service manual from samsung and goo from there maybe it wants a new memory card fitted
Oct 31, 2014 | Samsung RF261BEAEBC 25.6 Cu. Ft French...
My Samsung Refrigerator is making a noise that sounds like an old style door bell. It a loud buzz that occurs several times a day. Do you have any ideas?
User manual and parts list and diagrams.
SAMSUNG Refrigerator Parts Model RF217ACPN XAA
Your refrigerator has at least three motors with fans in addition to the compressor motor. The one most suspect is the one that passes air from the freezer to the refrigerator.
samsung refrigerator noise YouTube
Oct 19, 2014 | Samsung RF217ACPN - 20 cu. ft. French Door...
Miele freezer The fan on my standalone Miele
Hello David Riome,
Why are you discovering a FACTORY ASSEMBLY
does not fit ...??
(just be sure... KITCHENAID was one of my worst).
and keep in mind...
ALUMINUM only bends a very few times before
it breaks (soft, brittle & very difficult to repair).
((protect it)).
The FAN must be free of all obstructions to function.
If it is out of balance, worn or broken in ANY WAY...
REPLACE IT...
Make sure all wires and lines are ABSOLUTELY
NOT in contact with the fan bracket...
(secured out of the way).
Most of these newer units have aluminum evaporators
and a FAN BRACKET will easily wear a HOLE in
your REFRIGERANT LINES.
Like a saw... It may take a couple of years but
sure as winter follows autumn... $$$$$ damage
from conflicted refrigerant lines.
Move the wires and lines away from the FAN.
Carnac the Magnificent
May 13, 2017 | Miele Freezers
GDM-33SL-60 not cooling
Is the compressor (the football-sized case on the outside back of the refrigerator) making a continuous hum or other noise? A constant noise could indicate a serious problem with one or more components. This is a repair that should be left to a refrigerator service expert.
If you hear a clicking noise every few minutes, this means your condenser is trying to work but can't. If your condenser coils are clean, the problem could be the start relay, which triggers the compressor. Have a refrigerator repair pro determine if the start relay is the culprit and to replace it if necessary.
For more help identifying the causes and solutions, read Refrigerator not cooling. I hope this helps!
utube.png You-Tube video "sfMv4SgMjDs" placeholder
Oct 08, 2012 | Freezers
Black and decker chest freezer on frost in the upper half of the freezer, the other half going down to the bottom is just cold with no frost and also the top of the inner part of the door is making ice.
You may have a leak of refrigerant, you may have a warm air leak when the lid is closed, or you may just need to defrost it manually. use heat ONLY, do NOT poke at the ice or frost with anything
Oct 10, 2010 | Freezers
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer bought in 1996. Moved to new address 3
what brand refrigerator is it? model number?
Mar 22, 2010 | Freezers
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
Freezers Logo
95 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
