Question about Kenmore Refrigerators
The frame of the freezer section (which the freezer door closes against) is very, very warm although the freezer and refrigerator sections are fine. Particularly the bottom front of the frame.
    Guru:
  • 1,524 Answers
That is known as the anti-sweat heater. Sometimes it is electrical and some times it is refrigerant warmed (Yoder Loop).
Posted on Oct 13, 2010
Fridge section is warm after being closed all night. Power is on and turned the fridge control up to full and freezer down slightly
Many times those adjusters are mechanical, opening or closing a doorway across the ventway. the lever could be broken, or disconnected from the door. Also, is there anything blocking where cold air is vented to the refrigerator section? It could even be frost in the freezer section blocking the vent..
Nov 02, 2015 | Refrigerators
Tip
Refrigerator Defrost issues - Check those door gaskets
While failed defrost controls is more normally the reason for poor refrigerator/freezer performance, we can not forget about the door gaskets as being a possible culprit.
First, visually inspect the gaskets for signs of severe deformation or torn areas which could prevent a good seal. If either is suspect, replace the gasket. Also make certain that magnetic gaskets in fact have the magnets.
Next, grab a dollar bill or sheet of printer paper torn to about the size of a dollar bill. Test the gasket on all doors all the way around by placing the bill or paper onto the frame with the door open. Then, close the door, and gently pull the bill or paper out from the closed door/gasket. You should feel some resistance to the pulling motion. Test all door gaskets, all the way around. Replace any gasket which allow the paper to easily pull out of the closed door, or, figure out if there is something preventing the gasket from sealing properly.
Door seal leakage allow not only warm air migration, but moisture migration into the refrigerator freezer section, putting undo load on the cooling and defrost sections to both cool the air and condense the moisture (which is seen as frost on the cooling coils.), and melt the created ice from the cooling coil..
on Dec 11, 2009 | Refrigerators
Frigidaire Side by Side Model: PHS68EJSB0 The temperature is warm on both the freezer and fridge. They are at about 25F and 60F. I have cleaned the condenser coils and they are wet now. Initially, the...
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.------- The control board needs to be inspected.---------- If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.-------- But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak compressor.The refrigerant in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 21, 2011 | Frigidaire Professional Series PHS68EJSB...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Oct 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
