Question about LG Washing Machines
Lg fuzzy logic 6.5kg WF-T652A OE error. have checked drain pipe ,it's clear When put on spin cycle it sometimes starts to spin for 5 seconds then ceases & then tries to go again . You can clearly hear that it want's to start
  • scratcha785 Oct 13, 2010
    , I have check the belt & it is firm no slack, the drum will turn with the hand but not spin freely . I,ve just put it into spin mode & the machine spun, cutting out & starting again , I,ve checked the belt during this process & everything seems to be fine
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code OE means that the pump is blocked and signal is being sent by the control panel to the washer that the water isn't draining properly. Please also check that the washer is leveled properly, pump is not blocked with any foreign object, drain hose is not blocked and drain pump filter is clean. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
  • 11,896 Answers
Check that the tub can spin easily by hand. Should spin extremely easily with no belt on the tub. The tub bearings can seize up and need to be replaced. Make sure the belt is not stretched out either. I the tier is faulty this cycle can get skipped.
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
I have an LG Fuzzy Logic 4.5kg WF-452C Top loader. Put one load on and it worked fine. Went to put the second load on, and the water level lights are flashing and beeping, and the load won't start.
Take all the clothes outside put empty spin program if it finish without problem ur machine has no problem aftem u jusy check the inlet water filter and clean the filter every15 days,,
Apr 01, 2015 | LG Washing Machines
LG washer WM2501HWA quit mid cycle and had an OE error message. The drain filter was checked and was clear. I drained out all the water through the drain hose. For a time, the drum would not spin. When...
i believe if the water outlet is still good,,,,,u will have to loose out the pump from its cup , mayce something hooked its propeller inside the i cup or replace the water pump
Jan 25, 2015 | LG Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
My LG Fuzzy Logic 5.5kg WF-T552TH machine works fine on small loads, but if I put a large amount of washing it, just runs through water and never starts the wash cycle. Water just passes through.
This is a very common issue and simple to fix, the height of your drain hose is too low, it is siphoning the water out of the machine once the water level gets up near the level of the drain hose.
Mar 02, 2012 | LG Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Lg Fuzzy Logic 5.5kg Turbo Drum with I-sensor, Model WF-T552TH Washing machine goes through initial fill up, when changing to spin/wash works for 2 seconds, then stops spinning back and forth and shows dE...
There is a small magnet at the front of the lid that triggers the door error, mine was corroded and the lg people wanted $80 for a service fee.. Ha I went to my local hobby shop and got a small earth magnet and some super glue $1.50 later and she's fixed.. tadAaa.
May 11, 2011 | Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Loss of power on LG WF-T652A
I have the same problem as you. Machine was stopping intermittently in wash cycles - usually near spin/drain and sometimes just wouldn't turn on. Now it won't turn on at all...
Jun 22, 2008 | Washing Machines
Washing Machines Logo
550 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
