Question about Car Audio & Video
Aftermarket amp installed on 2006 silverado
Was wanting to find the wire to connect the remote turn on for my amp, my factory radio is bone stock, found several different answers regarding a pink ant. wire(power ant). But the only problem is my truck doesnt have a power ant. installed on it.
  • Kordy Jun 03, 2008
    Thanks a bunch. Every thing works just fine, and sounds great.
I am from GUYANA, S.A.and deal mostly with Japanese vehicles but I am sure of one thing.
Forget about the pink wire. Find the wire that reads 0 volts when the
ignition is off, and 12 volts when ign. is turned to acc. Connect your amp's remote lead, and you are good.
kev tech.
Posted on Jun 01, 2008
Connect the remote turn on any wire that goes hot when the ignition is tured on
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
What's the Motorola box under my back seat Chevy trailblazer 02 also I'm hooking a amp to battery where do I connect the amp turn on wire I guess it be remote wire
The motorolla box may be remnants of an old disk changer for the stereo. With an amp your power wire goes into the positive wire that goes to your battery, your ground wire will be connected to some bare metal close to wherever you decide to install the amp, and the blue remote wire will be connected to the remote wire that in on the wiring harness of your aftermarket radio ( I'm sure your not installing an amp with your stock radio). Good luck I hope this helps
Oct 05, 2014 | 2002 Chevrolet TrailBlazer
Why is rear stock subwoofer not working?
I need to have more info about how you installed it, did you use rca wires from the radio to the amp.? Make sure the sub setting on radio is turned on. Make sure rca wire are in the input connection and not output, also check you connection from radio that they're in rite place. I really need more info about the map of your wireing
May 10, 2014 | 1998 Ford Expedition
Step by step instructions
The pink wire connects the remote CD controller to the radio to enable playing of CDs through the amp via the radio. The DK GRN wire from the radio turns on the amp.
Feb 25, 2014 | GMC Yukon Cars & Trucks
Silverado radio wiring
Some trucks and gm cars have two kinds of systems one without a amp,and one without so judging by what you're saying you probably have one with a amp so yes you can but it is complicated and you would need to bypass amp so just get the kit that's required for your vehicle.
Jan 14, 2018 | Cars & Trucks
Installing aftermarket stereo in 99 silverado which wires from stock harness connest to aftermarket harness
connect the wires as indicated below
1999 Chevrolet Silverado C1500 Wiring, aftermarket stereo wire colors
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (Tape off) not used
Car Stereo Dimmer Wire: Brown (Tape off) not used
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Oct 22, 2011 | 1999 Chevrolet Silverado 1500
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Hooking up amplifier to stock radio in Lexus ls400 1991
Hi Robin, I think I may be able to help. The instructions are referring to an aftermarket stereo and not the factory one. Most aftermarket stereos have a blue wire that runs either the power antenna or an accessory that turns on with the radio(amp, eq, power crossover,ect.) As far as the RCA cables, once again, most aftermarket stereos have RCA outputs for an amplifier. Factory ones don't.You can go to Wal-Mart or ABC warehouse and buy a wire harness just for this particular application and then all you do is plug the harness into the factory harness, everything is all pre-wired so there is no guesswork involved and no mistakes.
Aug 23, 2009 | Pioneer GM5400T 2-Channel Bridgeable...
My cd changer, radio and amp are inter connected.the owners manuel say that if all are not hooked up system will not work. i install an after market radio but cant get the factory amp to come on
Hello moemoneymood,
Since you did not specify the make and model of your aftermarket radio, I cannot pinpoint specific connection problems. Most aftermarket receivers have a "remote turn-on" lead, probably blue, but sometimes blue/white, usually terminated with a spade lug. In addition to power and ground, the amp requires this lead to be connected in order to properly operate.
Start by checking the wiring from the old receiver wiring harness and see which wires and what colors went to the stock amp. Then connect the corresponding wires from your new receiver to the amp. Some OEM receiver/amp systems had power and ground taken from the same harness, so you may need to run those separately.
Apr 11, 2009 | Car Audio & Video
Car Audio & Video Logo
142 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
