Question about Sony STR-DA90ESG
Shorted out during a storm; fuses fine; trying to determine problem
I'm trying to repair the same model receiver. it shorted out during a storm and no surge protector was used. while i am not experienced as the rest of you, i would like to determine the cause of the problem. i took the top off and there are three circuit boards relating to power; the first has 3 fuses, the 2nd two fuses and the 3rd i believe 2. All of the fuses are fine. what else could have shorted out -- the output transistors? i don't know what they look like or how to test them. what should i look for?
  • Neil T Flanders
    Neil T Flanders Jun 02, 2008
    all the fuses appear to be fine. i dont know what exactly has shorted out; i just know that it has not worked since a storm when lightning struck the house. now it does not turn on. i took the top off and looked inside. i did not see any visible damage. all the fuses look to be ok. most are 125v and 2 or 3 are 250v.
    thankyou for replying
  • 1,512 Answers
Hoping you could give me a bit more information regarding your amp. Had any of the fuses blown? Just wondering what you mean by the amp is shorted out. Does it blow fuses or is it tripping an earth leakage circuit breaker?
Awaiting your advice
Posted on Jun 02, 2008
  • Graeme Ross
    Graeme Ross Jun 03, 2008
    Hi again, have you tried plugging it in again after it has been unplugged for a while, and see if it turns on after time to reset? Sometimes, power surges can affect the program counter to the CPU then scrambled, the unit may lock up.
    If still no go, from there I would check the standby power supply for correct operation. Normally a separate 12 volt transformer with regulator attached. Check the regulator output to confirm. If thats ok, get back to me here.:)
I turn on home theater receiver and it says,"check sp wires",then it shuts off
You have some speaker wires crossed or shorted.
inspect the speaker wires for shorting (cat/dog /mouse chewed em up?).
You can also disconnect the speaker wires and plug them back in one at a time to locate the shorted one , should you be unable to determine which wire is shorted.
Mar 23, 2013 | Audio Players & Recorders
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Not getting power to tv.Socket and plugs are getting power ,there was a thunder storm,but every thing else fine.
The problem of your tv is the power supply the thunder storm cause that. You should unplug your tv when not in use, try to check the fuse if busted, their are two classification of a busted fuse, if the fuse is only open try to replace it but if the fuse is all burned out dont just replace it, it has a shorted parts like the regulator and the bridge type rectifier
Jun 24, 2011 | Televison & Video
Car got wet during storm. now none of my rear lights work. what might be the problem
you have wires that are shorting out to the main body of car so check all the fuses inside car and in the engine compartment to see if any fuses are no good. It sounds like you have a short in those wires so if you have a multimeter and know how to use one that use it to see where the short might be at and replace fuses if need be and wires that shorted out too mostly black hard insulated wires like they got fried black char.
May 04, 2011 | Mercedes-Benz S-Class Cars & Trucks
Adapter not connected after power outage during a storm
sorry to tell.. however you adapter seems to have been shorted due to that outage during the storm, please replace your adapter or try repairing the same . This is what i understand with your question - if i have misunderstood , please clarify in detail about the issue you are facing...
Dec 01, 2009 | Acer Computers & Internet
I have a projectionTV Sony mod. KP48V75. During a storm the safety power fuse blew. It was 125V 6.5A. I replaced it with 125V 6A and so far everytime I plug the TV on it blows the fuse. I have been through...
Most likely the storm did damage to the power supply board (the G board in a Sony) which is part number A-1316-388-A for your TV. However the board is no longer available..It most likely has a bad regulator and possibly rectifiers on that board that are shorted. Complete board replacement would be the best solution.
Nov 03, 2009 | Sony KP48V85GRAY 48" Rear Projection...
Wii console will not come on. There was a storm the other night and power went out but the wii was not on. Only plugged in.
Thanks for using FixYa!
Its possible that your Wii just shorted. You need to open up the console and check the fuse. Usually, the fuse is the only thing that gets damaged during shorting. If you do not are unsure how to open up your Wii, Just bring it to a local technician and have the fuse replaced. I hope this helps.
Have a nice day.
- HotRatchet
Aug 01, 2009 | Nintendo Wii Console
HI I have a Philips 37PFL5332D/37B 37: LCD TV that
lightning usually will damage the entire power
pcb and signal pcb.try power pcb first .this will probably repair the tv.
Jul 18, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blown amplifier
I would guess that during the move, the speaker wires crossed and smoked one of the output amp sections. The output transistors are shorted and are causing the fuse to blow. If you can post hte model number, I'll try to get you more specifics on the parts that will need to be replaced.
Apr 01, 2009 | Arcam Audio Players & Recorders
Screen is blank, shorted out?
you need to send it to repair shop ............the fuse cant be easily replaced also other components inside need to be checked.........
Feb 02, 2009 | Tomtom GO GPS Receiver
Sony STR-DA90ESG Logo
165 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
