Blinking filer light after a new filter is put in
    Scholar:
  • 80 Answers
Must be reset in t-stat manualy!
Posted on Oct 13, 2010
My mower has a fh451v 15 horse Kawasaki engine and it runs funny when i put the air filter on it and its new ???
Any way you could try a filter that lets in more air? On some mowers, the long threaded bolt that holds the air filter on will actually go into the carb. Maybe it is too long?
May 25, 2015 | kawasaki Garden
Chevy uplander going uphill sputters and check engine light blinks multiple times?
Usually a sputter will occur under load conditions like going up hill from a lack of fuel. Start by changing the fuel filter.
Apr 23, 2014 | 2008 Chevrolet Uplander
Will a bad fuel filter cause the engine light to come on
Yes it will, Not because of the fuel filer itself but from the lack of fuel pressure causes other problems. Replace the filter and see what happens.
There also is a tank sock filter but it is usually NEVER it.
Hope this helps MIke
Apr 28, 2017 | 1998 Ford Explorer
Hi! I have a new Bosch Dryer. We can't seem to get it to dry. It stops after just a minute with a linter filer light flashing.
i take it you have cleaned the lint filter if so then it has a bad sensor reader in the filter system
Dec 22, 2010 | Bosch WTMC3510UC Gas Dryer
Oil Change
1/Open oil filer neck/hole above foot clutch
2/Drain the oil from cranckcase, drain bolt in front of centre stand. Use a catcher for used oil.
3/Remove oil filter case @ centre of engine block below rad, that hump looking item
4/Put new oil filter the reverse of taking oil filter off.
5/ Close drain hole securely
6/Put new oil into cranckcase abt 3L, check dipstick to see how full it is, if needed continue filling until proper amount is in the cranckcase.
7/ Close the filler neck and it is ready to play
8/ Good enough free advise?
May 03, 2010 | 2005 Suzuki Boulevard C90
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Van would not idle, I tried to drive it home anyway after leaving a stop sign it chugged and died after sitting for a few minutes it started and went another 2 or 3 miles and now it won't start is this the...
can be any thing-fuel pump-fuel filter-egr valve-ignition- turn key on and observe dash for a blinking trouble light if there is count it will be like 1long 2 short =12 for a code- try a couple of quick eliminations spray with starter fluid -if starts u have a fuel problem/filter-pump,if doesnt check for spark no spark problem ignition if both present and starts but wont stay running problem possible emission/engine sensors
Oct 25, 2009 | 1993 Plymouth Voyager
I have a 1993 Plymouth laser and have never changed oil before, but watched, not sure what to do.
Remove drain plug from oil pan to drain oil. Remove oil filter using filer wrench. Instatt new oil filter. Put oil drain plug back in. Check owner's manual for oil capacity, put all oil in minus one quart. Start engine let run for aproximately 10 seconds. put in rest of oil and check dip stick to ensure corret amont.
Oct 09, 2009 | 1993 Plymouth Laser
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
