Question about Gateway Computers & Internet
New gateway computer
Computer locks up and says it has no signal.
  • beauba Jun 01, 2008
    Computer powers up but monitor says no signal. When I do get a signal it will lock up during applications, including screen saver.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    locks, as in on the screen? and no signal, as in no wireless signal?
    Genius:
  • 3,587 Answers
Ahh..ok..so it's the video signal....that's from a failure.
Posted on Jun 01, 2008
Location of the speed sensors on my 1999 ford explorer
Vehicle Speed Signal
The vehicle speed signal is generated by the rear anti-lock brake sensor and sent to the 4-wheel anti-lock brake system (4WABS) module. The 4WABS module sends the vehicle speed signal via circuit 679 (GY/BK) to all systems which require a vehicle speed signal input.
Speedometer
The electronic speedometer receives a speed signal from the 4WABS module.
GEM/CTM Diagnostic Trouble Code (DTC) Index
GEM/CTM Diagnostic Trouble Code (DTC) Index DTC Description DTC Caused By Action P0500 Vehicle Speed Signal Circuit Failure GEM REFER to Section 308-07A . Take your vehicle an have it diagnosed , before you buy parts you don't need . Just a suggestion , could be a wiring problem , the speedometer gauge , computer etc...
Sep 25, 2016 | 1999 Ford Explorer
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Why won't the passenger door unlock?
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
A door lock switch lock or unlock actuation
A keyless entry transmitter actuation
An automatic door lock or unlock actuation
A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation.
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K?© resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
I'll post a youtube video on how to test the power door locks computer controlled , check it out ! Your problem could be a switch or the lock actuator , BCM , wiring etc.... you need to test it to see !
I'll
How to test computer controlled door locks
Mar 22, 2014 | 2008 Saturn Aura
My Mahindra Scorpio is not starting when I am scanning my Car these fault code are coming P1647, P1832 please give the solution
Definition of check engine code P1647:
Chrysler/Dodge/Jeep:
Hydraulic Cooling Fan Control Circuit High
Daewoo:
OVER VOLTAGE
GM:
Driver 1 Line 7
Honda:
Power Command Signal Circuit Low Input,or Power Command Signal Circuit High Input,or Engine Torque Signal Circuit Low Input,or Engine Torque Signal Circuit High Input,or Mode Signal Circuit 1 Low Input
Jaguar:
Linear O2 Sensor Control Chip (Bank 2)
Kia:
Linear 02 Sensor Control Chip (Bank 2)
Volkswagen/Audi:
Please check coding of ECUs in Data Bus Powertrain
Volvo:
Ford:
LINEAR O2 SENSOR CONTROL CHIP (Bank 2)
Definition of check engine code P1832:
Citroen/Peugeot:
Transmission Transfer Case Differential Lock-Up Solenoid Circuit Failure
Ford:
GM:
Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
Lincoln:
Mercury:
Oldsmobile:
Sep 23, 2013 | Cars & Trucks
I have a 2000 ford windstar that I tore the ignition out of.now the theft light is on and wont start.can I change the steering column and the computer and get it to start without taking to dealer.
Not exactly.
If you replace the key lock and the sensor is functioning, you should be able to start the van.
The computer and instrument panel are in sync, so if you replace either component they have to be reset by a Ford dealer. The sensor in the key lock sends a signal to the instrument cluster, and if the signal is right, the cluster sends the signal to the computer which then activates the necessary circuits to start the engine. The key code has to match the cluster and the computer.
Apr 20, 2013 | Cars & Trucks
Engine delays 3 min
Hello, You have a failed ignition lock cylinder, the wires that give the signal to the computer that allows the engine to start and run are broken where they leave the lock cylinder. To replace you need to remove the steering wheel, the air bag tape, the signal light switch to get to the lock cylinder. Wish I could help more.
Sep 07, 2010 | 1998 Cadillac DeVille
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Showing stong signal, but computer won't connect. has picture of lock between computer and signal.
Check your Wireless Security settings.
What are your current settings for your desktop and the router/gateway?
Apr 22, 2008 | Computers & Internet
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
