Question about Whirlpool Refrigerators
I bought a second hand whirlpool refregerator model wrx42rwh6. First, it was freezing everything in the fridge section such as strawberries, tomatoes, rice etc. so I turned the temprature nob towards less cold side but I did not check what was going on the freezer section. But now freezer is just freezing ice but not anything else. that means temprature is going upto 0 degrees but not below that. Could you please suggest some solution. Thanks. Cheers. Raks
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
SOURCE: fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Posted on Nov 15, 2008
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
SOURCE: DOMETIC RM 1350 FRIDGE GET HOT AND COLD
Ok, I realize I'm a little late on chiming in here, is this unit located in a slideout, and/or the top outside vent is in the wall not a roof located vent?
If so then the issue is that there are fans that are necessary to circulate air thru the hot coils. And there is probably a malfuntioning thermostat to turn these fans on/off. I had this issue with same fridge in a Gulfstream motorhome, and the temporary fix was to pull the faston connectors off the thermostat and tied them together with a 12V fuse, and taped it up with electrical tape to keep it from shorting on fridge chassis and parts. Replace the thermostat at your conveniance, as these fans are now running whenever fridge is on, and will run your batteries down if not plugged into shore power.
Posted on Aug 24, 2009
  • 3 Answers
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Posted on Jan 26, 2010
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Whirlpool fridge ed250fwhx freezing everything
Your model should be ED25QFWHX and all you need is to replace the refrigerator thermostat you can see also all the parts diagrams of your fridge to the above link
Mar 05, 2012 | Whirlpool Refrigerators
I have a whirlpool s20brsb21 and all to often everything freezes in the fridge compartment for no reason
Make sure that the fin tubes on the back are not loaded with dust, clean off and don't over load the freezer section. If there is no room for air flow the temperature will keep getting colder to compensate for low air circulation, thus freezing items in the lower section.
Feb 07, 2012 | Refrigerators
Whirlpool fridge model no WRX42RWH6. No power seems to get to the fridge, ie nothing works, it stopped erruptly as if it had blown a fuse?
Daniel I will need to know if everything means the lights also and a double check of your model number. I I was not able to locate the model WRX42RWH6 in the US database. Also I want you to unplug and pull refrigerator away from the wall then remove the lower cover and feel the top of the compressor. I need to know if the compressor is hot, warm or too hot to keep your hand there. Also let me know if you are located in the UK or Canada. Check your circuit breaker and voltage coming from you outlet if possible. I need to determine if this failure is caused by a defective component on refrigerator or if possibly you have too many other appliances plugged in on the same circuit. This will cause the circuit breaker to trip especially if your refrigerator goes into defrost. let me know as soon as you can and I will stick with you on this until we find the answer, Thanks, John Tripp/AKA Sea Breeze
Nov 03, 2011 | Refrigerators
The ice shoot on my whirlpool fridge keeps freezing up.
the shoot door isn't closing tight,there's a solenoid that's in there that closes the door,next time send the model number look up on the right hand wall near the ceiling in the fridge section and you'll see it so i can look up your machine and give you the part number.
Sep 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
Water is dripping from a vent inside the top of the fridge section of the refrigerator. Model is a whirlpool wrx42rwh6
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Whirlpool Refrigerators
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
