Question about Garmin StreetPilot c340 GPS Receiver
It is stuck on acquiring satellites and won't go further.
  • amarano342 Oct 13, 2010
    Thanks. I'll try it
    President:
  • 4,070 Answers
Hi! If it's stuck please reset it. You can find a small hole on the bottom where only a paperclip tip can fit. Use a paperclip on pushing the reset button. Hope this helps and thank you for using FixYa!
Posted on Oct 13, 2010
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
The GPS seems stuck on acquiring satellite. Any fix?
Usually if you did not use the GPS for a long time, it would take quite a while to acquire the satellite. Be patient!. The other reason is to make sure that you are not in covered area, go to outside and try again, it may take as long as 5-10 mins. Good luck!
Sep 30, 2014 | Garmin nuvi GPS
Greetings . . . I turned my Garmin 2720 on in my
Take the GPS out of your van to an area with a clear view of the sky. Power the unit on. If the unit is working correctly, then it will acquire the satellites. You can then put the unit back in your van. You may have to reposition the unit to keep the satellite lock.
If the unit does not acquire satellites outside, then the unit is defective.
Mar 03, 2017 | Garmin StreetPilot 2720 GPS Receiver
New Garmin approach G5 will not acquire satellite
if you havent already charged the batteries, do that first before trying to use it...but it on the charger for a few hours, then take it outside in clear view of the open sky and turn it on...it could take up to 30 minutes to initially acquire the satellites from the off position.
try not to move the gps while its initially acquiring the satellites.
if that fails, let me know and i will help you further, but im sure someone has already told you to take it back, but the new one will do the same thing (if this is new out of the box) and please dont listen to anyone that tells you to do that or tells you to replace the batteries or even an update.
bill
Jun 20, 2010 | GPS
MY Garmin first Said that it was acquiring a satellite then it is stuck in one city and won't clear to set another route. what can i do?
Did it actually acquire any satellites. If not try the reset button on the back. If nothing then do a master reset - you may lose some of your locations previously stored or user data. If none of these work or before you try them try an external antenna.
Oct 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Acquiring satellites
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
525 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
