Question about Asko T712 Electric Dryer
I need to repalce the belt on an Asko T712 front loading dryer. Do I go in from the front or the back?
I took the top and back of my unit apart. Then from the back it is still not the eaisiet of tasks.
Posted on Mar 10, 2011
My asko t721 dryer is one week old and i do not have a manual.it stopped in the middle of a cycle. it had 3 bath towels in it.. it starts when i push the button but will not stay on for more than a few...
Hello, welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a excessive long vent or flex vent being used ( stay away from flex venting ) plugged lint filter, plugged vent ot partially plugged etc.
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate further...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko T712 Electric Dryer
Element in the back seems to be heating but not spinning around. Cleaned filter.
the belt,motor,idler assemblage, drum glides and rollers are all parts the will effect the rotation of the drum. Here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Asko T712 Electric Dryer
Hours for towels or sheets to dry
a dryer can only handel so much if you over load it it cant tumbel the load inside of it so the warm air wont dry them out,,,also what is it set on??? low or hight heat?? how wet are the sheets when you put them in the dryer??? is the dryer getting a good air flow,, it need to breath in lots of air,,,,and that hot wet air need to get out freely,,,if its even slightle blocked the dryer cant work well,,,how often do you clean out the dust filter in the dryer,,,(this should be cleaned every time you use it) also if the sheets just tiy them selfs into a big knot they wont dry
i hope this was of help to you
Jun 27, 2010 | Asko T712 Electric Dryer
Is the belt replaced from the front or back?
Back. Takes some skill, but that is how it is done. The back comes off to do this.
May 28, 2010 | Asko T761 Electric Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
Will not dry after 2 hours
Hello. Actually this is not a ventless dryer, there is a vent hose whic typically comes with the appliance. If the appliance is not vented out-of-doors it should at least be vented into the room. Pull the dryer out from the wall so you can inspect the rear of it and you will see the vent hole. If need be, go to any hardware store and purchase a dryer vent kit.
Here is a clip from the Asko T712 literature.
Easy to install Simply plug it into an electrical socket and connect the ventilation hose provided.
Dec 19, 2009 | Asko T712 Electric Dryer
Alarm F1 stoping dryer type T712, what the reason?
For information, behind front panel are optional hidden sensors and one of them had to be reset.
K,W.
Apr 14, 2009 | Asko T712 Electric Dryer
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko T712 Electric Dryer Logo
207 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
