Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge side by side GSS25TSR model. The freezer side defrosted everything the other day and now is set on 2 at the thermostat. even at 2 the freezer is totally frozen. The frige side is set on 4 and the crisper drawer is frozen. Also the line for in the door water is frozen. Is there a way to test the thermostat or reset anything?
murdozzz2
  • 75 Answers
SOURCE: Refrigerator moisture
hi there your fridge has whats called a wet wall evaporator where it freezes up then turns to water and runs down the wall , if you are getting water sitting in the base of the fridge check the drain hole which is sittuated at the bottom of the wet wall evaporator for any blockages ie. bits of food or paper labels.
hope this is of some help
Posted on Dec 13, 2007
  • 126 Answers
SOURCE: Frozen Freezer Coils
all of the above the heater is on the coil you will seethe wires the therm. is on the top of coils timer could be at lower back of refrig.
Posted on Dec 14, 2007
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    GE Frig model TFX20JRBK ww with icing on freezer
    I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
    Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    My freezer defrosts too often
    replace defrost timer
    Oct 12, 2009 | Refrigerators
    Whirlpool Estate series fridge/bottom freezer no longer gets cold
    How to check everything
    http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
    If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
    check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
    You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
    Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
    Variance in freezer compartment temperature
    check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the control board.
    Sep 04, 2009 | GE GSS20IEM Side by Side Refrigerator
    Ge frig does not freeze on freezer side
    Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE Model # DSS25PFMD WW, lights and fan are working not cooling
    Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
    GE Fridge not cooling well, frost in freezer,back wall and coils
    Aug 17, 2009 | Refrigerators
    GE Model tfx24f defrost not working.
    Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
    Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
    Freezer has developed some frost in the back
    This is a fairly easy problem to solve. First thing you will need to do is defrost the ice on the inside back panel of the freezer. Then remove the back inside freezer panel. You will need to remove your freezer shelves to do this. Once the panel is removed you will need to defrost the coils and surrounding area. Once defrosted you will see your defrost heather on the bottom of the coil and a defrost thermostat on the top of the coil. The defrost thermostat is about the size of a quarter and about 3/4 inch thick. It will be mounted on the coil line. If you have a multi tester you will be able to check continuity through the heater by unpluging it. The defrost thermostat is a bit more tricky to check. It will not read continuity once it is warmer than 50 degrees. The defrost thermostat is a fairly inexpensive part so if your heater is good you may want to just replace the defrost thermostat and see if the problem goes away. The other possibility would be your control board. It is located on the back of the refrigerator and has a metal plate covering it, with sever 1/4 inch screws. This board causes most failures on your model refrigerator. Also a point to remember. This board has had several new upgrades from the one originally installed on your refrigerator. So make sure if you get a new one that you get the listed number I have given you. The older ones are cheaper but they are also not updated and will not function properly on your refrigerator. The following parts listed are the possible parts you will need. Please let me know if you need one and I can ship it to you in about 1-2 days. I do not charge shipping and I give free advise. Thanks and good luck with your frost problem. you can reach us at.
    Michael Anderson
    Anderson Appliance
    (865)945-3808
    mca0824@aol.com
    defrost thermostat. #WR50X10068 $21.57
    defrost heater #WR51X10042 $56.50
    control board #WR55X10656 $185.50
    Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE (PSS26MSRSS) Side by Side Refrigerator Logo
    179 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
