Question about SanDisk 2GB microSD Memory Card
How do you manually open a memory card adapter?
    New Friend:
  • 42 Answers
Just bend it enough and the plastic will crack open or you can use something like a knife and run it along the perforated edge of the card. It actually pops open easily if you try.
Posted on Oct 13, 2010
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Jan 10, 2013 | SanDisk 4GB microSDHC Memory Card
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
I just cant put in the sd memory card into the slot...the slot is slightly bigger and u just cant feel the memory card clicking in...once it kinda fell into the slot and got stuck inside... does this mean...
I know that HP sucks but if you insert the card into the correct opening it will work. If you are incapable of doing so, have someone else do it for you.
Sep 01, 2017 | HP Pavilion dv5000t Notebook
I am using window 7 enterprise my computer can recognize the sony memory stick pro duo adapter with 1 GB card but cannot open it neither can format it. please tell me any solution.
check the small lock switch on the adapter usually located on the edge of the adapter. check and see if in lock or open position. if its in lock position toggle the switch to open position and you should be able to read as well as write date to and fro from the sony memory stick pro duo adapter. good luck
Sep 08, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
How do i get the data off of a sandisk adapter and on to my computer?
A sandisk adapter does not contain any information at all as it is just an adapter. You need to have a smaller memory card plugged into it because as stated above what your talking about is just an adapter. If you do have the smaller memory card plugged in you just simply open my computer ,after it is plugged in, and open the removable disk drive/folder and then select your data by dragging and highlighting it and right click, copy, and paste the information to wherever you want it.
Apr 30, 2011 | SanDisk 2GB microSD Memory Card
Sandisk transflash adapter (1GB) not opening or reacting on my notebook
There's a lock on memory card adapter, maybe that's the reason it's not working, so to make that work just push it to the other side. raghav0007_2.jpg
Mar 19, 2011 | SanDisk 1GB microSD Memory Card
How can i download songs to my cellular memory card?
Hi welcome to Fixya.com. Please follow the Instructions. Instructions
  1. Insert the microSD memory card inside the microSD memory card USB adapter by removing the cover to the USB adapter and slipping the memory card inside it before replacing the cover.
  2. Plug the microSD memory card USB adapter into your computer's USB port.
  3. Locate the music files that you wish to add to your cell phone and drag and drop the files to the USB drive to move them to your microSD memory card.
  4. Remove the USB adapter from the computer and remove the microSD memory card from the USB adapter.
  5. Open the microSD memory card slot located on the side of your cell phone and press the microSD memory card within the slot until it clicks into place.
  6. Go the "Menu" on your phone and click on "Settings and Tools."
  7. Click on "Memory" and then "Card Memory."
  8. Click on "My Music" and then click on "Options" and then "Move."
  9. Check all the music files that you wish to add to your cell phone and then click "OK." Click "Yes" when prompted to confirm that you want to move the files to your cell phone.
Hope this solves your problem. Please feel free to ask questions on Fixya . Have a nice day. Bye
Mar 12, 2011 | Cell Phones
Do you need an adapter 4 a memory stick pro duo in a 5 in 1 read
No, just insert the Memory Card in the 5-in-1 Card Reader slot. The Memory Card will appear on the "My Computer" or "Computer" window. Click on that to open the contents of the Memory Card.
Good Luck!!!!!!
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
How do i do this
Too little info, but I'll give it a shot... Assuming that the adapter thing is a USB adapter ( not a mini-sd to sd adapter ) you need to install media into adapter and plug into the available usb port on side of laptop. Depending on age of laptop, there may even be a media card slot ont the side of the laptop, and the adapter may not be necessary. Any how, after the device is inserted into the laptop, the OS should recognize the device, install any needed drivers, and should be good to go. Next open up "my computer" and click(double click) on the device and it should open up. Open up the folders until the desired picture files are located, then just copy and paste to the folder you want to save in. ( if you can't find, do a search for "pictures" on that drive )
Jan 02, 2008 | SanDisk Memory Media
SanDisk 2GB microSD Memory Card Logo
44 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
